Question My Samsung RU8000 died, looking for a similar one
Host84
Hi all!
My Samsung 55' RU8000 give up on me while I was playing Warzone. Samsung is refusing to repair it but amazon is happy to give me a full refund.
paid: £569.00 I think it was on offer at that time.
Currently, I'm using it for NETFLIX, AMAZON PRIME, YOUTUBE, and PS4. also, I play videos which are in avi, mp4, mkv, mov. But I never watch any Standard Tv channels.
Which TV would be best for me?
I was thinking 55" would be ideal.
Price, ideally under £600.
So the Tv's I been checking now every day but still, I can't decide.
1.HISENSE 55U7QFTUK Quantum Series 55-inch 4K UHD HDR Smart TV with Freeview Play, and Alexa Built-in (2020 series), Silver [Energy Class B] £599.00
2.Samsung 55" TU7100
HDR Smart 4K TV with Tizen OS [Energy Class A+] £479.00
3.Samsung 55" TU8000
HDR Smart 4K TV with Tizen OS Black [Energy Class A] £549.00
4.LG 55NANO796NE 55"
4K UHD HDR Smart NanoCell TV - Black color (2020 Model) [Energy Class A] [Energy Class A] £499.00
5.LG 55UN81006LB 55'
UHD 4K HDR Smart LED TV with Freeview HD/Freesat HD - Light Grey Pearl color (2020 Model) with Alexa built-in and Magic Remote included [Energy Class A] [Energy Class A] £599.00
Maybe not important but the tv will be on a wall mount which is easy to turn sideways.
Any advice gratefully received.
Dodgexander
If you want a similar spec TV, and a slight improvement try to aim for the Sony XH9005 as a minimum, also sold as the XH9296. There are refurbs sometimes here if you need it cheaper:
Other TVs are downgrades in motion (60hz panels) or a downgrade in contrast and blacks (LGs use IPS panels at 55").
See here for all the best buys:
Samsung RU8000 is mid tier, so you want that or higher.
Host84
Unfortunately the XH9296 is way over my budget. And there isn't any refurbished one for sale now.
I understand that all from my list would be a downside, but do you think for my needs it would be enough?
Or should I wait for a Sony price drop?
tvdavid
prb I would go with HISENSE 55U7QFTUK on the list next best on that list.
vickster
From the guide
LG 55Nano86 / 55Nano85 - Cheapest avenue to true HDMI 2.1 ports and 120hz panels. Dolby Vision HDR and wide colour gamuts. LG differences here: LG_TV_LineUp_chart_2020_v1.0.pdf
Sloppy Bob
The store is often, but not always, refreshed on a Thurs/Fri, but you have to be quick.
how about the LG 55NANO866NA 55 Inch?
Unless you need wider viewing angles, that TV has an IPS as opposed to a VA panel and I'd try to avoid that if possible as they have poor contrast, uniformity and blacks compared to VA panels.
If you were watching all those file formats via USB stick, be prepared to possibly be disappointed with a new TV. A lot of TVs now play less audio and video formats than they used to, a firestick running Kodi can fix this though if it's a problem.
Dodgexander
LG TVs use IPS panels, see my last message here:
There is also the Samsung Q70T at 55" which isn't a downgrade compared to your TV, but it also may be more expensive. Its not as good value as the Sony XH90/XH92.
I know the Sony is out of budget, that's why I suggested the Sony refurb store. Its going to be impossible otherwise really to match your current TV in quality.
Maybe consider stepping up in size to the 65" TCL 8 series (C815). That TV uses a 120hz VA panel like your current TV.
