FlyingBig said:
Yeah the xbox and sky+ boxes make a hell of a noise, surprising that folk can here their sets buzz over that already existing noise.
I find the SKY+ box noise is a different buzz and changes all the time depending on whether you are recording, playing back, or just viewing.This buzz is generally constant.
The TV noise is a different pitch. The only way to reduce the noise as ive said is to go into the brightness sensor option and turn it on, so the sliding bar moves from right to left until it stops at the optimum level. The noise level ( or pitch) of the sound changes with each movement of that bar if that makes sense ,so if it finishes up completely to the left then the noise is less obvious. But I find having the brightness sensor on makes the picture too dark.
Anyway ive just got back from PC World, Comet and Currys and have had a look at 2- 40", 3- 32" and 2- 26" models from the same range and they are all pretty much silent, unless u actually put your ear on the grills at the top of the TV! so im not convinced it should be making a noise like it is...
Roll on Engineers visit on Friday!
