My room size needs help :)
Discussion in 'Home Cinema Speakers' started by Teresa, Oct 14, 2004.
  1. Teresa
    Teresa
    Hi there
    I am wanting to purchase a new speaker setup to sit with my PIONEER VSX-AX5i..... I am currently looking at the new Sat genie system from mordaunt short but will it be able to handle my 5Mx4M room ?
    I know they are pretty new speakers ,but if anyone has them or keff eggs or the avant premier plus setup let me know there thoughts? I am not asking about sound quailty just filling the room... Can they do it?
    I can accommodate floor standers but thats an option at the moment, and I would rather save space if possible and its just so much easier to wall mount the sats.
    But I dont want to waste money on sats if they are not up to the job
    I watch movies mainly
    If push comes to shove I will get the EVO 3B setup
    your thoughts?
    cheers
    T
  2. Teresa
    Teresa
    can anyone confirm if sats are up to a 4m x5m room ? i have read posts on room size dateing back 2 years but no deffinitave answer
  3. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    The 2005.2 are enough to play more than loud enough in your room, make sure your receiver has a 120hz setting for the crossover... :smashin:
    Of course Q1s or other regular size monitors should sound better with proper power, I would stay away from floorstanders, sat/sub are easier to fit in a normal room without bass problems... :rolleyes:
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I would send a PM to 'Tons of fun' as he works for MS and should be able to give you a real answer to your question:smashin:
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Why is my answer not real... :suicide:
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Well i never know with you Lowrider :D I was just thinking he would know from experience ;)
  7. njr
    njr
    Aug 23, 2002
    115
    16
    Berkshire
    Ah Antonio,
    So this is where you have been hanging out!
    Teresa,
    In this instance I would go along with what Antonio suggested, For AV duty sat/subs are the best combination IMO. For music however.... ;)
    njr
  8. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I do know, I recomended them to two friends, and heard their systems afterwards, larger rooms than Teresa too... :smashin:
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Yes, every where else is too agressive nowadays, except for Audio Asylum...
    It works as well for music, believe me... :lesson:
