My remote control extender doeasnt work with telewest ?? *help*
Discussion in 'Cable TV & Virgin Media TV' started by husk24, Jan 28, 2003.
  1. husk24
    husk24
    hi guys
    i have a pyramid remote control extender which controls any electrical item with a remote control. However i cannot get my telewest receiver to work with it. Anybody have any idea whys that and how to rectify this - plz
    thanks
    dave
  2. Fernsehman
    Fernsehman
    I bet you mean "Powermid". Yes I know why it won't work because I spend half my life reading the technical stuff at the satcure web site. Look at the technical section, page 11:
    "Will Powermid XL work my cable TV box?"
    You'll find your answer there! :p
    Fman
  3. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Basically it won't work with pace digital cable stb's because they use an extended IR and the extender does not support this.
    You will also have major problems getting a multi function remote to work these stb's, I think the extended IR is called IRDA but can't quite remember.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  5. Fernsehman
    Fernsehman
    By the time you've added carriage and VAT that seems more expensive than satcure's price (£52.14 inclusive for next day delivery)? But I don't buy on price alone. How does delivery and technical backup compare? Anyone dealt with either of these companies - letsautomate.com and satcure.com ?
    Fman
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    I bought my pronto amonst other things from letsautomate and they have been very helpful with a good technical bias when needs be...
    JJ
  7. husk24
    husk24
    yes it is the powemid. Digi sounds pretty cool but im not paying that price. anybody know of a cheaper device?
    thanks for help
  8. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    choice is limited for IRDA senders :(
  9. Fernsehman
    Fernsehman
    Worth paying the extra then. Anyone know satcure? I might buy one of these DigiEye things myself. Looks nicer than the Powermid.
    Fman
  10. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  11. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Hey cool or what, these guys have used there free NTL web space to develop then sell a product that will sort out a problem that NTL along with Pace created and have never bothered to solve.
    Sweet justice to make money out of NTL's incompetence using NTL's web space for the advertising to a reach the perfect target audience. :D :D :D
    Of course if they were to find out about this they would be so :blush: that they would remove the site claiming that the free webspace is only for personal use has per terms & conditions. The real reason being they don't like to think that we the customers already know how incompetent they are so wouldn't want it on show:D
