My PSU is only 225w
Discussion in 'Computer Components' started by henry1234, Jan 21, 2003.
  1. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    I am about to install a 9500 PRO
    My PSU is only rated at 225W.
    I have:
    40GB Deskstar
    Pioneer DVD
    Ricoh CRW
    Floppy drive
    Will it work or kill the PSU?
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Depends on the CPU and HSF, even if the're lowpower I still think its a bit close to the mark though!
  3. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    CPU is 1GHZ Athlon, on KT7A mobo.
    The 9500 PRO is working but I think I'll get a 350W enermax anyway.
    Now if I could just change the refresh rate on the radeon, which is locked at 60hz before my head explodes!!!!!!!
    P.S. The fan on my 9500 Pro is virtually silent. I had to put my fingers under the fan to make sure it was actually working. Must have a lucky fan.
  4. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Refresh rate being locked is probably either the monitor or the monitor driver, try selecting the Sony GDW900 monitor and you'll get all widescreen reolutions and refresh rates, otherwise you're going to need powerstrip if its anything non-standard.
