My PSP can't find the music track I ripped. Can anyone help me please
Discussion in 'Playstation Forums' started by tony kop77, Mar 26, 2005.
  1. tony kop77
    tony kop77
    Sep 27, 2002
    6,174
    103
    Northamptonshire
    +278
    I have ripped a cd track and saved it in a folder called music on my PSP but can't find it using the PSP menu.
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    You have to make sure its in the right folder, otherwise the PSP wont see it.
    Try changing the folder or rather getting rid of the folder and puting the mp3s directly into the music folder.
    It also wont work with anything except MP3's and Atrack 3. if u try to use a different format like AAC it wont work.
