My Pronto has died
Discussion in 'Home Cinema Control & Remote Controls' started by Pommy, May 13, 2005.
  1. Pommy
    Pommy
    Jun 11, 2004
    29
    3
    Melbourne
    +6
    Well picked up the pronto yesterday and found that it wasnt working, so turned it over to check the batterys only to find that the back cover was all disstorted and when removed the cover top end were the springs are is MELTED the batterys look fine (no leaks) but the plastic is way out of shape, its a 940 which ive had from new and has not been abused so this is a supprise but what was more of a worry is that it had been sat on the sofa and Im lucky that the heat generated to warp the plastic didnt scorch or set the sofa alight !!!
    Has anybody else had similar trouble with the pronto before?
    I had been using uniross re-chargeable batterys
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Yep, had exactly the same thing happen me. Notch up another one for Philips quality control.
