My Projector Bracket
Discussion in 'Projectors, Screens & Video Processors' started by miniroll171, Feb 2, 2003.
  1. miniroll171
    miniroll171
    Thought I would post links to a couple of pics of my new projector bracket if anyones interested.
    It's a TV bracket that I bought from B&Q Superstore for £16. It comes in silver an matches the projector quite well. I've had to sit the projector upside down so it projects at the right height, and had to fix some sticky runbber feet to the top (now the bottom) for it to stand on.
    Now all I'm waiting for is my 963sa DVD player to arrive so I can watch LOTR in it's big screen glory :D
    Neal
    http://www.magames.pwp.blueyonder.co.uk/proj/1.jpg
    http://www.magames.pwp.blueyonder.co.uk/proj/2.jpg
  2. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    I use exactly the same bracket, got to manufacture a ceiling mounting bracket next, or just turn the bracket upside down and drill holes for smal mounting screws and add a couple of spacers.
  3. Spacecat
    Spacecat
    Apr 1, 2001
    2,942
    London
    +610
    i put one of those in a few years back for my old sharp and now for my Tosh, i used the one with the extendable arm so I could adjust the distance if needed for future projectors.
    Its a good solution for a tricky problem
