my plasma has stopped working.HELP!
Discussion in 'Plasma TVs' started by miniman, Aug 16, 2003.
  1. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    I have a 503mxe and this afternoon it suddenly switched itself off.
    i turned off the power and swiched it back on and it came on in standby mode so I pressed the power button and the green light came on for a second then went off, leaving the red light flahing twice every 5 seconds.
    I disconnected the 5002 card to see if that was the problem and it was still the same.
    doe's anyone know if there is a reset switch and where it is? or does anyoone have any ideas as to the cause? I have the mains running through a surge protector and have phoned john lewis who will send an engineer.
    Typical I'm on holiday and the premiership has started. God i'm p**sed off.
    Cheers Mark
  2. ncpl
    ncpl
    Jan 21, 2003
    348
    Surrey
    Mark,
    have a look on the Pio site and see if you can get the service manual to see what the flashing light is meaning. I'll have a look to see if I already downloaded it.
  3. midlander
    midlander
    Sep 3, 2002
    183
    +6
    This happened to my 503MXE a couple of months ago, but it's alright now and hasn't happened since :clap:. I think it's due to turning it off then on again too quickly - it must be some protection circuit to stop damage. I use a Pronto and it can send the standy signal twice if I'm not careful. Anyway the solution was to turn it off at the mains, leave it for a while and then turn it back on.
    HTH
    Martyn
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    miniman
    The MXE is basically protecting itself against some form of internal problem.
    Call your dealer and they can have Pioneer service out to you in a day or two and they can most often resolve any issues on site.
    Best regards
    Joe
  5. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    Cheers for the help. I think joe is right it seems to be protecting itself. Phoned J.L and they are sending someone thurs.
    mark
