KamSandhu44
Established Member
Hi all,
Another home refurb thread.
I planning to start a refurb in March.
I have tried to put together a plan that I think will work and wanted to get the forums thoughts.
This is the proposed floor plan.
I plan to run at least 4 runs of CAT6 to each room with the central point being under the stairs.
The 'Family Room' will be the main TV/ Projector room.
I was planning to run active HDMI cables to the Family and TV room and use the CAT6 cables for backup.
I am also planning to wire for a future projector, so further active HDMI and CAT6 cables in the ceiling.
Speaker config wise, I am wiriing for a 5.1.4 system.
The TV room will only have SKY HD going to it. The Family Room, to start with will only have SKY HD and XBOX One. Eventually there will be an AV amp and blu ray player added.
There is no home automation involved, I just don't need it or have the budget.
Is there anything I am missing or should consider.
