My pioneer 505xde just went pop
Discussion in 'Plasma TVs' started by hddvdman, Apr 10, 2005.
  1. hddvdman
    hddvdman
    Feb 11, 2003
    6,070
    somethere over there but not near here, there
    +155
    the screen just went pop and now is dead, 3 months old what do i do?????
  2. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    jesus
    This sound very worrying.
    Maby it s a power supply or sth.
    Call your dealer to check it out.
    If it s sth that can't be fixed, he got to change it with a brand new screen
    if it s under warranty
  3. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    Contact Pioneer directly. They tend to respond well with items in warranty facing such problems.
  4. hddvdman
    hddvdman
    Feb 11, 2003
    6,070
    +155
    hi
    thanks for your help - there coming to see it tommorrow
  5. diverse
    diverse
    Jan 21, 2004
    159
    16
    let us know what goes on?
  6. hddvdman
    hddvdman
    Feb 11, 2003
    6,070
    +155
    Repaired Quickly Apparent It Was Was Of The X 7 Y Boards They Replaced Both And The Psu Board - Quick Tip On Plasma Buzzing - This Could Be Due To Loose Screws On The Boards When Tightened This Reduces The Buzzing Noise....
  7. diverse
    diverse
    Jan 21, 2004
    159
    16
    where would one tighten these? are they on the Panel or Media Box?
  8. hddvdman
    hddvdman
    Feb 11, 2003
    6,070
    +155
    On The Plasma Undo The 20 Screws At The Back Of The Plasma At Your Own Risk And The Three Main Boards (very Easy To See) Tighten The Screws Holding The Boards Onto The Plasma - The Engineers Did This For Me As I Watched So Looked Easy But Make Sure They Said That You Power Down The Plasma First Then The Media Box, Take Power Leads Out Etc
    Like I Said This Is What They Told Me So Could Be True Or Could Be False All I Know Is That The Buzzing Is Alot Less Than Before... If Any
