My pin not working - Panasonic DMRHWT130EB
Discussion in 'Freeview & YouView' started by JUSCRUISIN, Sep 6, 2017.
Tags:
  1. JUSCRUISIN
    JUSCRUISIN
    Sep 6, 2017
    3
    4
    Daventry
    Having bought my unit Ifilled in Owner ID-Data Entry and created pin number and other required and validated but now if I try to go in where the pin number is required it does not recogonise my pin number , also i have found that child lock is on and again trying to delete it it requires pin number but says incorrect pin ,,,,,, help ,,,, getting rather frustrated
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,937
    +6,782
    Welcome to the forum.
    The owner ID number is not the same as the separate Pin number required for parental guidance, and you have probably not set that number yet, in which case it will still be at the default of 0000.
    Try that.
  3. JUSCRUISIN
    JUSCRUISIN
    Sep 6, 2017
    3
    4
    Daventry
    Hi, yes i tried default 0000 with no success
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,937
    +6,782
    OK - Reset the Parental PIN number by the following method:
    The PIN number for parental control returns to the factory preset (“0000”).
    1 - While the unit is on, press and hold [OK], the yellow button and the blue button at the same time for more than 5 seconds.
    • “00 RET” is displayed on the unit’s display.
    2 Repeatedly press play button (right) until “03 VL” is displayed on the unit’s display.
    3 Press [OK].
    • “INIT” is displayed on the unit’s display.
  5. JUSCRUISIN
    JUSCRUISIN
    Sep 6, 2017
    3
    4
    Daventry
    Hi, I tried your suggestion when on a TV channel and all it does is bring up screen heading ALL DVB CHANNELS . I tried on FUNCTON MENU HD and tried on PLAYBACK CONTENTS-TV GUIDE-TIMER RECORDING-NETWORK-SET UP with no effect or display . I have then gone on SETUP menu and applied on each sub group with no result or display . I have also tried on INITALZE -DEFAULT SETTINGS and but still nothing and even gone on to DEFAULT SETTINGS but it does state if applied PARENTAL CONTROL SETTING are not reset if i wished to continue .
  6. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,215
    +409
    This is one of the reasons why I avoid using these PIN setting facilities. They do seem to go wrong, and I can recall having a brand new Panasonic box that required a PIN to do anything, even though it had never been changed from the factory default or set by me. I digress. If you're still having issues you probably should contact Panasonic UK technical for assistance.
    Clem
