my pc turns itself on during sleep
Discussion in 'Desktop & Laptop Computers Forum' started by santosh123, Jan 5, 2012.
  1. santosh123
    santosh123
    Aug 7, 2011
    64
    when i go to sleep, i also put my pc to sleep. btin the the morning i wake up to it being on. i have checked the task schedule in windows and cant seem to find anything odd. do you have any idea what the problem is?
  2. Cleeecooo
    Cleeecooo
    Apr 6, 2011
    Could it be any USB device that's plugged in waking it up?
  3. LJx
    LJx
    May 29, 2009
    3,259
    uk
    +437
    Yeah, could just be the mouse moving or something. I would just shut it down and wait the extra few seconds for it to start up
  4. santosh123
    santosh123
    Aug 7, 2011
    64
    I only have keyboard, mouse, and webcam
    Plugged in
  5. eNxy
    eNxy
    Aug 9, 2008
    611
    Guildford, Surrey, UK
    +31
    Is your PC connected wirelessly or ethernet? My old PC used to wake on sleep because of the ethernet controller on the motherboard.
    If you go into your control panel and navigate your way to network connections, and you should see the local area connection adaptor, in most cases it would probably be a Realtek controller. If you right click it and go into its properties and then into configure, there's a power management tab on the far right. It may be checked to allow the device to turn on the computer on any activity.
