Question My Panasonic TC-P50S30 Flat Screen TV, the optical (Toslink) sound output stopped sending sound out?
PanasonicTVFS
Hello,
My Panasonic TC-P50S30 Flat Screen TV, the optical (Toslink) sound output stopped sending sound out? The red light won't light either. There is no analog sound output on this model of TV do you have any suggestions on how to correct this? Your help with matter will be greatly appreciated
Clem_Dye
You could try a factory reset and/or check that the firmware is up to date, but it sounds as if the optical interface has died, especially as you can't see a red light. Have you changed any of the TV's settings recently, and perhaps disabled the interface by mistake?
Clem
JayCee
There are no settings in the audio or any other menu which allow the optical out to be disabled.
LG CX 4K OLED TV Review: The best TV of 2020?
