my Panasonic DMR-EH60 is region 2 is it worth sending back get a multiregion one
Discussion in 'Blu-ray & DVD Players & Recorders' started by the blue angel, Aug 27, 2005.
  1. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    is it worth sending this one back and get a multiregion one from multiregion magic does it affect software in anyway
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Do you really need a multiregion modified machine? I have the odd few region 1 DVD discs but I usually use one of my multi-region dvd players for this altho my Panasonic E85 which was purchased already M/R modified will also play them. Hardly worth the trouble of sending back your newly purchased machine just for this reason.
  3. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Do you expect to buy any DVDs which are not region 2 or 0 (0 play on anything)?
    You'll only get non-R2 or 0 if you buy outside the UK or Europe.
  4. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    guess i will keep it otherwise i have to pay 25 pounds back to the company
    for sending it back and they could charge me extra because i have used it
    i no i have 7 days to cancel
  5. crater
    crater
    I have a Panasonic DMR-E95 and DVD-S35 (player only). I unlocked them using a gadget from DVDCodes (http://www.dvdcodes.net). It took about 20 seconds for each. What they do is send you a chipped remote and instructions for the model you've specified. When you've used it (you can only use it once), you put it in a stamped return envelope (supplied), post it and Bob's your uncle!
  6. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    if something went wrong and sent it back once i used the chipped remote
    would that void the 12 months warranty with who i bought it from
  7. jerryat
    jerryat
    Aug 25, 2005
    Nr Plymouth
    I don't think doing it that way is worth the trouble. The Panasonic shop here in Plymouth, for example, will do it for £20.00 AND, because they do it, the guarantee is not voided!!
