My new ceiling mount and AV Rack
Discussion in 'Projectors, Screens & Video Processors' started by Jeff, Nov 16, 2001.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Since I'm useless with my hands (the wife nods behind me), I got a chippy in to build me a Ceiling mount and an AV rack. The ceiling mount is for my Plus U3-1080 DLP projector and ISCO II anamorphic lens, the idea of the design is that I can attach perspex sides and turn it into a hush box. Here is a pic
    http://photos.yahoo.com/bc/yerkess/...dir=/My+Photos&.dnm=Ceiling+mount.jpg&.src=ph
    The other thing I got him to make is an AV rack, I'm using the meter cupboard with a hole into the main room this way I have very easy access to the front and back of the equipment.
    http://photos.yahoo.com/bc/yerkess/...oKzV&.dir=/My+Photos&.dnm=AV+Rack.jpg&.src=ph
    Jeff
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    That's a big mount for your projector. To allow for bigger projectro perhaps, but definately not a bigger lens, that is a mother...
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The Ceiling mount is big, but the picture probably makes it look bigger than it really is. It's basically a 50CM cube. The lens is a bit of a monster isn't it. :)
    Jeff
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    What other projectors can the lens fit onto?
    I may be lucky to get a new projector (fixed panel) over xmas.
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    It should work with pretty much any fixed panel projector, but the longer the throw the better (less distortion). They are normally used with 4:3 projectors but they can be used with 16:9 projectors to turn them into 2.35:1 ratio.
    Jeff
  6. Hermie
    Hermie
    Jun 3, 2001
    3
    Suffolk
    Nice box, I'm thinking of doing somthing similar for my newly installed PLV-30. What are you planning to do for ventilation ?
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I'll probably use a couple of low noise Papst fans (RS sell them), I'll leave the electrics to someone else though, too many close encounters. :)
    Jeff
