S
sohc
got it at the dollar store for a buck. used a cheap soldering gun to make holes. isnt the most graceful thing, but it works swell.
Wow, it's so... practical.sohc said:got it at the dollar store for a buck. used a cheap soldering gun to make holes. isnt the most graceful thing, but it works swell.
Sasso said:And why is your screen green and yellow?
shadowritten said:Okay chaps - p**s take over. Shows initiative if nothing else ...
KeanosMagicHat said:As a serious comment in a world where people are obsessed with materialistic pleasures (myself included sometimes) it's refreshing when you see someone who truly values function over form.
This case provides all the protection SOHC wanted and cost next to nothing.
Edit - quick question, how come you have a Silver unit with Black Buttons and White Text?
Hadn't seen that combination before, or maybe it's a trick of the light (like the screen)?
sohc said:its a black/black unit with regular white on black text.
