My Movies in MCE on 360?
jaspain
Sorry if this has been asked before but does anyone have My Movies plugin running on the 360 extender and able to watch DVD Movies from it as I get errors when trying to watch them.
I have copied them over using the plugin and can watch fine on PC. Is this a codec issue?
Many Thanks
Jas
CDR
I found that .iso's had to be in a folder, and you use "folder location" to point to it, not "file location"
It took a while to get working but when it did it was very good (Although I dont use it anymore)
jaspain
hi
they are not as iso's I have just used the my movies plugin to copy them to HDD.
Do they need to be isos?
Jas
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
