Quantcast
My modest front room set up
stuproberts
Hi everyone,
long time lurker here who has finally got to a place where they’re reasonably happy with their set up (well as happy as I can be lol). Think my next step is either going to be 2 speakers at the rear and move the fx to the sides, or drop the fx and fit 2 atmos as my amp is only 5.1.2
AV Set Up
TV
Sony Bravia KD65XF9005BU
Speakers
Monitor Audio Bronze 5 Front
Monitor Audio Bronze Centre
Monitor Audio Bronze Fx Rears
Subwoofer
BK Gemini II
Blu Ray Player
Sony Bdp-s790
Network Streamer
Nvidia Shield Tv Pro 2019
Surround Amp
Denon AVR-X2500H
Satellite System
Sky Q
Nas Drive
Seagate Go Flex 1Tb
Seagate Personal Cloud 5Tb x 2
Speaker Cables
QED Xtc fronts and centre
QED Micro rears
HDMI Cables
Audio Quest Pearl Blu Ray to Amp
Audio Quest Pearl Amp to TV
Audio Quest Pearl Sky to Amp
QED performance Streamer to Amp
Sub Cable
QED reference Sub
Tv Unit
Venice range in walnut adapted to fit equipment
Tv Bracket
Rfiver Tv floor stand.
Thnks for looking
gibbsy
Very nice. If you bring the centre speaker so that it sits proud of the front edge of the cabinet by around 25mm then that will help get rid of some unwanted reflections off the cabinet top. A soft rug in front of the cabinet will also help.
stuproberts
Thanks for the advice, I’ll give that a try. Have got a rug on the floor but it’s about a metre away so will try moving it closer
Silverblack
Nice setup!
DodgeTheViper
I'd be tempted to bring the front L & R further forward also. Can those FX's be mounted to the sides ?
stuproberts
Hi dodge,
yes they can but swmbo would rather I keep them at the rear. I am allowed to lower them so maybe atmos and not 7.1 is the way to go in the future. Just trying to work on her to allow the LCR to be moved further forward 😃👍🏻
DodgeTheViper
Explain to her that you've invested a lot of money and time getting to where you are now. And while it does sound great, to absolutely maximise what you've done so far and to plan ahead, the FX's should 'ideally' be at the sides. Doing this will maximise your Atmos plans, as I see your room anyway ;)
stuproberts
Will mention it later (after a glass or two 😂)
Similar threads
