My modest bedroom setup
Discussion in 'Members DIY Home Cinema Showcases' started by GodAtum, Jan 8, 2012.
  1. GodAtum
    GodAtum
    Sep 18, 2007
    337
  2. ChristovJN
    ChristovJN
    Sep 16, 2010
    187
    Manchester
    +44
    Lovely setup, do a bit of cable management (even if its just to tidy them up as opposed to hiding them) and it will be spot on :)
  3. Nerved One
    Nerved One
    Jan 28, 2009
    1,141
    87
    +339
    I would not class this as modest mate, that's a great set up you have there, the MA are mighty fine home cinema speakers. Only suggestion I'd make is to rearrange things a little there. I'd try to get the front speakers wider apart by swapping the sub and right speaker around...and then position the tv as close to the middle as you can.....appreciate compromise needs to be made, but I'd not want that radiator on being so close to my electronics !
  4. GodAtum
    GodAtum
    Sep 18, 2007
    337
    I've still got some QED speaker cables to cut and stripe so that's why the cables are a messy lol.
    Unfortunately my bed sits to the right so it would be blocking the right speaker which might be a problem? My rears are a problem as well and my chair is right up against the wall so one speaker is to the side and one is behind me.
  5. Silverblack
    Silverblack
    Sep 24, 2008
    3,068
    +578
    Although your room is tight on space i have to say that i like your setup alot, the tv and speakers look the business i bet it sounds wicked!!!:D
  6. Incrediboy
    Incrediboy
    Apr 13, 2005
    822
    Singapore
    +83
    Is your tv stand the wrong way round?
  7. nespresco
    nespresco
    Jan 3, 2009
    605
    28
    Bristol
    +30
    Really nice set up, especially in a tight space! If you move the centre speaker so that the front of it is in line with the edge of the stand you will/should notice a slight improvement in sound quality.
  8. 1979scotte
    1979scotte
    Mar 3, 2007
    284
    +17
    Jesus! That`s your bedroom? Speakers are better than i`ve got in my dedicated home cinema. Good Job. :smashin:
  9. Moley UK
    Moley UK
    Dec 26, 2011
    156
    +21
    I think it might be! Good spot!
    Them speakers look proper loud for a bedroom! :)
  10. Wayne00
    Wayne00
    Dec 4, 2008
    563
    +15
    Wow nice speakers! Major overkill for a bedroom surely!? I take it you live at home with the parents? (Hence why this is in the bedroom and not the lounge!? Do they not mind the noise?
    What are these kind of speakers like on low volume? Where they expensive?
  11. GodAtum
    GodAtum
    Sep 18, 2007
    337
    I dont really listen loud anyway so these speakers sound great at low volumes. I often have problems hearing speech as the music and sound effects often drown it out so these speakers are great as the speech is clear :)
    It cost me around 3K for the 5 speakers, amp and cabling.
  12. Grangey.
    Grangey.
    Apr 24, 2006
    5,773
    Oxfordshire
    +885
    yep it is- the silver leg bits on the top shelf are always at the front!
    Great setup there- just get it out of a bedroom and into your own pad :smashin:
