My Modded Xbox 360
Fozzy17
Established Member
Not everybodys cup of Tea, But i got Fed up with Looking at a Creamy Coloured 360, So Fitted a Clear Case, Clear Fan Ducts And Stripped out The DVD Drive so that its Clear and you can See the Drive Spinning, and fitted two strips of low light Led's.
The Led is now moved from the Below Strip as i fitted it to the DVD tray (Doh!)
Aminator
Established Member
ooo that looks very very very nice, how much the clear casing cost ?
Hate to think what that did to the warranty :D
Fozzy17
Established Member
I think it was £40 Delivered, case and tools plus a split power adapter and two strips of low light Led's.
DD3
Established Member
but what about the cost of hermetically sealing your room and the decontamination chamber to ensure there's no dust in the room.... else I hate to think how $!tty it will look in a couple of months :rotfl: ;)
looks nice now though.
kasumi
Established Member
Nice looking clean mod there man. Well done.
For that extra bit of cooling you can fit a small blue led fan to the front of that cpu finned heatsink to help blow through and out through the rear clear tunnel.
m1ket
how did you find the whole case replacement process? im considering getting the black version of the case..
also i see you dont have a HDD connected, can you replace that aswell?
Fozzy17
Established Member
Changing it was ok, it will take around a hour to do if you take your time,the HDD was disconnected as i was testing it for the first time, no soldering for the led's, it comes with a double connecter so it will power motherboard and Led's, Guide Here.
The link http://www.xbox8164adapter.co.uk/ghost.swf works fine, however you need to have the flash player installed.
http://www.adobe.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
