My Living Room
lky2k23
]In the last week brought my amp and speakers and discovered this website - I have lots of plans and not really a big fan of the setup i currently have.
Did think twice about putting this pic up but though what the hell, get it on here then i can track my true progression.
My next 'thing' is going to be to get rid of my cds and have some wireless music sorted out :)
lky2k23
New TV - Panasonic TX-P46G15. Purchased from Richer Sounds after a price match with Costco :)
Wallmounted easy enough on a dry wall. Seems stirdy enough, used decent wall plugs from Screwfix.
lky2k23
Changed the old cabinet and using my old cd/dvd ikea shelving unit at the moment - think it works ok.
Need to get cables hidden - thought i would be able to just drill through the plasterboard and drop them down but when trying this (in a few places) i have what i describe as a waffle styled joist system so dont know what to do - dont know which way to go at the moment...Think i might need to do some thing around the tv now as there seem like a lot of 'space' not sure at the moment, But this is it for now anyway..
lky2k23
Got some Apollo Ambient Lighting. Went for these due to the quality of pics and reviews ive seen in this forum. Very happy with the results!
lky2k23
its like a waffle ######### all over the wall from what I can make out.
Bizness
Very nice, like the backlighting. :thumbsup:
Did you put the lighting on teh wall or the back of the telly?
lky2k23
Its on the back of the TV. Have 3 24" lights on top and sides at the moment. Was advised to get more but happy enough at the moment with the look of it. Dont have the funds to see what it may look like anyway..
Bizness
This is what I'm struggling with with my TV at the moment. It's so thin and wall hugging that the lights look poo. Especially as they're not the same on both sides as my TV has all the connections down the left hand side of the back of the TV.
Grrr.
adbrad
nice setup, looks like its really coming along well.
:thumbsup:
I noticed you have a sony dh800 amp, ive been looking at these for a while and just wondered what your opinion of it was.
By the way, you look like a guitar fan, i know its tiny but check out my avatar, its santana playing last year at silverstone (took the pic my self). :smashin:
lky2k23
Wires gone...
Now i know this is prob really poor and not the 'correct' thing to do, but i drilled through to my bedroom at tv level and near the skirting board and fed the wires through this way to the TV. My wardrobe covers this in the bedroom so i thought it was a quick and easy way to do it in the end.
Only wire that caused a problem was the ambient lighting, this is now plugged into the bedroom plugs to enable it to reach, and just put masking tape on the unit for the time being.
Let me know what you think.
lky2k23
New toys purchased this week :)
Blackout blind put up
HTPC XBMC
Legends
Just have to get some new speaker wire now and mount the rear speakers, hide the speaker wire and ill be finished and happy I think. Need to spend time with the Harmony remote now.
lky2k23
Only problem I have at the moment is im not sure if the glare off the 20quid ikea frames is a big deal or not impacting my viewing....time will tell i guess...
L
londonmandan
hi,
Is XBMC running on your XBox if so how did you do it?
lky2k23
XBMC is running from my PC mate not xBox sorry.
Might end it all....dropped my Harmony
Logitch are calling me back tomorrow to let me know what my options are. Its a dark day though...
rusty73
lky what was the outcome from logitech??
lky2k23
logitech couldn't help me at all unfortunately - but i got a new one through insurance.
Need to figure out a way to get the old one fixed though, anyone have any ideas? its only a replacement screen I need after all..
adam81
Putting the cables through the wall is cowboy genius...
The new owners will get a shock when they see the holes in the wall when they move the cupboard.
Looks good
Similar threads
The Best Amazon, Disney+, Sky & NowTV Movies and TV Shows Coming in October 2020. Tom's Thumbs.
Trending threads
Latest News
Sony Android TVs add Now TV app in UK
  • By Andy Bassett
  • Published
System Audio Room Service correction app free to iPhone users
  • By Andy Bassett
  • Published
MBL brings high end Hi-Fi systems and speakers to UK
  • By Andy Bassett
  • Published
Roku announces Streambar and adds Airplay to streaming devices
  • By Andy Bassett
  • Published
Amazon Prime Day confirmed as 13-14th October
  • By Andy Bassett
  • Published
