My lass bought a wii. How do I connect wii and 360?
Urban Splash
Hi all,
My lass decided to get a wii. This has put a spanner in the connection works!
I think the best way to connect the 360 would be with component, however, component connection with the wii is supposed to display the best image possible.
With most tvs having 1 component connection is there any way I can connect both with the best picture quality possible?
I want to buy a 40" ish lcd with full 1080, still not sure which one though
Nomino
Hi all,
This has jack-crap to do with LCDs. Why are you posting here? Just do a google search and look for TVs that have two component inputs, or component and VGA, then buy a component-to-VGA adapter. It's not rocket science...jeez.
Besides, if you think component makes such a big difference to the already low-quality image with the Wii, think again. All component does is further show how poor the graphics look. I know Wii isn't all about graphics, I'm just saying...
Urban Splash
Because im connecting to an LCD.
Here man, if you get nothing useful to say, don't bother posting. Now get back to school
Sonic67
You can buy an amp and do the component connections through that. My Denon amp has component in and out for several inputs.
http://www.denon.co.uk/site/frames_...C=3&action=prodlist&Pid=&main=prod&ver=&sub=1
If you click on the various amps you can check what the inputs etc are.
Otherwise you could get a switch box.
http://www.consoleplus.co.uk/product_info.php?products_id=716
http://www.maplin.co.uk/Module.aspx?ModuleNo=97952&doy=12m12&C=SEO&U=strat15
http://gear.ign.com/articles/452/452131p1.html
Nomino
Haha, dimwits and their schoolistic assumptions. I'm on holiday, from work...laughing at idiots like yourself who know nothing.
If you'd read my post, the solution was right there - get a TV with component and VGA, and then buy a VGA-to-component adapter, or a TV with two lots of component inputs. Are you blind, as well as thick?
So you're connecting to an LCD...that you don't have yet, because you can't be bothered to make the effort to go and do some research, or even understand the results of that research?! :rotfl:
Urban Splash
my you have so much wisdom.......
btw, cheers for that sonic!
S
Sarah Nya
If you're at work thats even worse, I'd expect such inane comments on a board such as Gamefaqs but not here :rolleyes:
The guy was asking a simple question you could have just answered it instead of bashing him.
LV426
Administrator
Staff member
Moderator's Comment
Just for the record, Nomino's attitude and behaviour here is quite unacceptable and has resulted in two formal warnings. Nomino's ability to post is currently suspended.
T
taxa
Good, what on earth was that all about lol perfectly fine question from the poster.
youngsyp
Hi all,
Buy a Sony KDL-40W2000 and a VGA lead for the 360. Jobs a goodun. You'll have 1080p resolution for your 360 and the best connection (component?!) for the Wii :smashin:
Urban Splash
I thought that. Is VGA as good as component for the 360? Until I buy the TV, I cant really form an opinion as i'm currently viewing my 360 via my pc monitor using VGA.
I know the quality with the wii is poor anyway, but I still want to display the best possible, which i think is component.
thanks for the help !
