Quantcast
My HP microserver build
m0t0k0
Due to the recent offer at ebuyer for the HP ProLaint Microserver for only £129.99 after cash back I was finally able to convince the misses to let me buy my own server.
This is my journey to server nirvana
As you can see it is quite small and not bad looking, even if it’s going to live in the cupboard
It has 4 HDD bays at the front but also has an e-SATA port and extra SATA header on the mobo bringing its total internal HDD support to 6 drives
You can also see on the door there are spare screws and a torx bit allen key all contained and easy to access
It comes supplied with this HDD and 1GB of EEC memory, both of which are a waste of space and it could retail without these but a little cheaper.
The whole top panel comes off to allow access to the ODD bay which will eventually hold the two drives which don’t fit in the slide out bays.
Looking inside you can see the Mini SAS cable which leads to the 4 SATA sockets on the backplane
A proper internal USB header to take a memory stick with unRAID on it or similar and the extra internal SATA socket which can be used to serve an extra HDD in the ODD bay
To get the most out of this little server the internal and external SATA sockets have to be used to provide 2 extra HDDs data connection when seated in the ODD bay.
Unfortunately by default some of the SATA sockets are set to run in IDE mode and a hacked BIOS is needed to unleash the full AHCI mode. Just look on google there are many guide and BIOS files available
m0t0k0
If you slide the board out (to do this you will need to disconnect the Mini SAS cable for which you will need a jewellers screw driver as it is very stubborn) you will see it comes with.
Four PCIe slots a x1, x4 and x16 unfortunately the x1 and x4 are right next to each other. This allows you to use HPs KVM hardware but means in reality we are limited to x16 and a x1 slot
As I have been a good little boy Santa bought me just what I wanted
Mmmmmm BlackGold 3650 quad DVB-t2 card so now I record 4 HD streams of HD rubbish!
Some users have stated the fan is too loud (I think they are using it as a HTPC) but if you find the same then with the help of this guide the fan can be swapped! HP Proliant MicroServer | silentpcreview.com
IT HAS A NON STANDARS PIN LAYOUT
These are the drives which are going into the machine for now as HDD prices are just silly
We have a 2TB Hitachi 1TB Samsung and 250GB drive which came with the microserver all of these will be for data and the OS will be dumped on some generic 2.5” drive I have somewhere
I will be using a copy of WHS 2011 as it is just so cheap but also integrates very well as I have a almost completely windows centric network. It will back up my local PCs and even allow remote web access of my files.
In fact I still have not bought my copy of this yet as I just installed a copy from usenet and keep resetting the trial period like you can in W7 so I have 120 of use before I have to buy a copy.
WHS Install Guide
You can find an install guide here http://www.informationweek.com/byte/...p-os/231000924
And a video on how to setup user access to you server here
Next up are some of my favourite programs I have ever used
Using the programs below you will be able to autonomously download music, movies and TV series. The content will then be unpacked mete data added and place into the predefined folders of your choice
You will need a UseNet provider which can be had for less than a tenner a month for unlimited downloads a good guide to UseNet can be found here
All information about binary newsgroups and usenet | Binaries4all Usenet Tutorials
• SABnzbd+ SABnzbd.org : Home of SABnzbd+, the Full-Auto Newsreader
a Open Source Binary Newsreader written in Python.
It's totally free, incredibly easy to use, and works practically everywhere.
SABnzbd makes Usenet as simple and streamlined as possible by automating everything we can. All you have to do is add an .nzb. SABnzbd takes over from there, where it will be automatically downloaded, verified, repaired, extracted and filed away with zero human interaction.
(UseNet is a bit like torrent but it will max your internet connection and you don’t have to seed)
• SickBeard Sick Beard - Internet PVR for your TV Shows
The ultimate PVR application that downloads and manages your TV shows
Sick Beard is a PVR for newsgroup users (with limited torrent support). It watches for new episodes of your favorite shows and when they are posted it downloads them, sorts and renames them, and optionally generates metadata for them. It currently supports NZBs.org, NZBMatrix, NZBs'R'Us, Newzbin, Womble's Index, NZB.su, TVTorrents and EZRSS and retrieves show information from theTVDB.com and TVRage.com.
Here is a good guide for SickBeard with explination of how to setup post processing
How-To Turn Your Computer into a Supercharged TiVo with Sick Beard - How-To Geek
• CouchPotatoApp CouchPotatoApp.com
CouchPotato is an automatic NZB and torrent downloader. You can keep a "movies I want"-list and it will search for NZBs/torrents of these movies every X hours. Once a movie is found, it will send it to SABnzbd or download the .nzb or .torrent to a specified directory.
Setting up CouchPotato can be quite daunting but there is a good guide found here
Couch Potato Install, Setup, & Configuration Guide for Ubuntu & Linux Mint! : Ainer.org — Counter-technology Guides, Information, & News! Featuring Linux Mint & Ubuntu, SABnzbd+ & Sick Beard, Couch Potato & Headphones, XBMC & more!
It is written on a Linux machine so the install is different but the configuration is very helpful
• Headphones https://github.com/rembo10/headphones/wiki
Headphones is a SABnzbd add-on that automates your music downloading. It's written in Python so it works on pretty much all systems, and it's easy to setup and configure.
You can import all your favourite artists from iTunes, and keep an eye out for any new albums they might be releasing.
It can be configured to work with a few search providers, including NZBMatrix, NZBs.org and Newznab servers. Just enter your account details and you're ready to go.
Headphones requires Python to be installed to work you will be wanting the Python 2.7.2 Windows Installer which can be found here Download Python
Accessing your programs WebUI over a network
All of the above programs can be administered over you local network via a web browser.
I won’t go into specifics as the wiki pages of each are very helpfull but there are a couple of things to remember
• Each program will be assigned a port for access usually 8080 or 8081 each program needs a unique port. If you try to start a program on a port which is already in use it will not start. Please read the relent wiki for help with this
• Each program needs to be allowed through the firewall on the local machine (your server)
Use this guide if you don’t know how to allow a program through the firewall
Windows Firewall - Add or Remove an Exception - Windows 7 Forums
How to get you programs to auto start at boot up
Now your biggest problem with WHS is the fact that it is headless so when you switch on the server no users get logged in. This means that any programs set to start automatically will not start up.
But there is an easy way to get around this
1. Remote Desktop into your server
• On a client PC Click start and type “remote desktop connection” click enter
• Enter the server name or IP address
• Enter Administrator as the user
• And the password for the servers administrator account (You entered this when you installed WHS)
2. Install the programs you require on the server
3. Click start Administrative Tools  Task Scheduler
You will be greeted with this screen
4. Click “Create New Task” the following pics will show you how to set SABnzbd+ to auto start but it can be applied to any of the programs
How do I pool a set of hard drives and or protect my data
First thing to note is RAID is not a backup it can save you data if a disk dies. But it won’t restore a file because you accidently deleted it or you house burnt down!
I suggest all you precious data like wedding photos and the like are backed up to somewhere off site crashplan Online Data Backup & Storage – CrashPlan – Backup Software, Disaster Recovery will give you unlimited backup for about $3 a month
There a many ways to skin a cat here and ultimately you need to find which is best for you and your usage.
But I will do my best to explain an little about what is out there and what I think is best
Ok so the way I see it you have two options
Hardware RAID
For this on the microserver it supports (I think only in the 4 slide out bays)
RAID 0 which has no redundancy and is used for speed but its effectiveness is debatable
RAID 1 half your disks are used as an exact replica of the other half. Very easy to use and reliable as you have two copies of everything but it’s very inefficient as you lose half you data space to copies
You could install a RAID card to give you access to more of the standard RAID levels but this will cost you money (quite a bit for a good card) and if you card broke your data would be lost until you can find an exact/compatible replacement (maybe not so easy in 3 years time)
There is more info about RAID here if you interested
RAID - Wikipedia, the free encyclopedia
So by looking at these options they are not very efficient and are dependant of specific hardware there must be a better idea right?
Software RAID
Just like with hardware RAID there are many implementations here and you can find a couple of the main attractions here
SnapRAID
My choice here is FlexRAID FlexRAID Wiki | Rethinking storage data management
• Data centric, not Drive/Device centric (any data, any size, anywhere)
• Supports both Snapshot and Real-Time parity data protection
• Supports creating and expanding a storage pool with volumes/devices containing existing data
• Provides massive energy saving features (**)
• Multi-platforms support: FlexRAID runs on Windows, Linux and WHS
• Provides the greatest data safety possible and the lowest risk of data loss (*)
• Its FREE!
• Allows me to see my drives as a single pooled drive
• The data on my drives stays as it was before it entered the array so if I pull my drive out I can read it like normal in any machine
• I can have redundancy from any number of disk losses
• Has support for SMART monitoring
(*) Failure beyond the tolerance level will result only in partial data loss unlike all other solutions in the market which would result in complete data loss
(**) Allows drives to spin down: only the drive/device containing the accessed data will need to be activated when reading/writing to a storage pool
So what can you do?
FlexRAID works very differently for other RAIDs
I can pool a set of drives
I can protect a set of drives
I can protect and pool a set of drives
So say I have in my server 4 x 2TB drives
• I can assign 3 of my drives to be DRUs (data risk units) where all your data is held
• Assign 1 of my drives as a PPU (parity protection unit) where the information to recover a dead drive is stored
This gives me
6TB of useable data space
Redundancy from one lost drive
Alternatively I could assign
2 x DRU
2 x PPU
This gives me
4TB of useable data space
Redundancy from 2 lost drives
You can have as many DRUs and PPUs as you wish but what is you drives are not all the same size?
What if I had 2 x 500GB drives and 2 x 1TB drives?
• I can group the 2 x 500GB into one PPU
• Have the two 1TB drives as DRUs
This gives me
2TB of useable data space
Redundancy from 1 lost drive (In fact I would have to lose both 500GB drives to lose my whole PPU)
It has so much functionality and can be fine tuned to your liking so read the wiki and get on the forum if you’re interested
Mapping your shared drives/folders to other PCs on your network
Coming soon
toastedone
Nice read :thumbsup:
spyder viewer
Very good, is the Blackgold going in there? What software will you use to drive it Mediaportal? Will the cpu be able to handle the 4 streams of high definition rubbish (at least you'll be able to see clearly it's rubbish). Where's the forth pci-e slot?
m0t0k0
Really interesting thread. Subscribed.
Thanks guys!
Yea the BG is in the x1 PCIe slot (the x4 slot is next to this on the right in the picture)
Yea MediaPortal TV server can be installed very eaisily on WHS have a look at this site TV4Home - The all-in-one TV solution!
Can it manage 4 simultaneous HD streams? I don't know I was under the impression the card does all the demodulating and just pumps out a TS stream on to the hard drive. This will then be played back on a HTPC with an i3 2100.
I'm going to try get some coax from the ariel to the server today and get it going
Maniac618
Sounds like FlexRAID is amazing. I want to ultimately use it with 4x 2TB drives for data and 1x or 2x 2TB as Parity. I'd be using FreeNAS I think, although I wonder if it is safe to use FreeNAS 7 instead of 8 so I get to use iTunes server / DAAP.
m0t0k0
FreeNAS unfortunately is not supported as they move back to FreeBSD
but Open Media Vault is a debian port of FreeNAS and as such will be supported
But I think as of yet there is a OpenMediaVault FlexRAID user base of 1 :( but as its debian bast it should be pretty to setup
IanW1977
Are you using sab remotely ?
liamcooper
Interesting read.
I decided to go with OpenMediaVault because I prefer a linux OS for machines like this (and similarly my Acer Revo). Just thought I'd point out that the server comes with 2GB RAM, not 1GB as stated in the first post.
railfrog
It all depends which model he has.
The N36L comes with 1GB, the N40L has 2GB
m0t0k0
Yep I have the N36L just posted a link to the new version as the old link I have was inactive
Mine is also clocked at 1.3Ghz which I'm currently trying to find out if I can adjust!
The whole top panel comes off to allow access to the ODD bay which will eventually hold the two drives which don't fit in the slide out bays.
Where did you get the bay converter set from? i cant find one that slides in like that as there no mounting holes in the chassis?
m0t0k0
It is a mixture of two
The first being the C shape metal brackets which were just the cheapest 2.5" to 3.5" adapter I could find
The second is 4 x anti vibe rubber mounts I just bolted it all together to fit it in there. (cant remeber where from just had the in my box of bits!)
The microserver is supplied with 4 special bolts which protrude enough to be guided along the slots in the bay.
Ah yes, there in the door, so any 5.25" to 3.5 adapter will do then? :D
whiskers
@m0t0k0 ,
I have a very similar build to yours:
Microserver 40 L
Blackgold BGT3650
WHS 2011
Mediaportal - Server and Client for now
MSI GT 520
8GB Ram
Connected to my tv via HDMI
Have you tried to play the HD streams yet? Try as I might I cannot get the audio to work -standard def audio is fine. There is a tip ( No Audio on DVB-T2 HD broadcasts - BlackGold ) on the blackgold site for MCE but obviously this doesn't apply. does your hd audio work?
Thanks,
Whiskers
m0t0k0
Hi whiskers I have had no problems with the audio just with the picture being bloacky and covered in artifacts. I made a post about it on the mediaportal forum and have had quite a lot of help.
I was shown another post where a revised TsReader.ax file is shown to help with the HD broadcasts vid and audio (it helped my picture) which you can find here [Bug] 1.2.2 TV sound problems - Page 3 - MediaPortal Forum
And finally the epg for the HD stuff is garbled (this is due to compressing apparently) and this thread helped me combat that What DVB-T2 Freeview HD Card UK - Page 4 - MediaPortal Forum
RSRAVI
Hi mate how have you setup sab did you use windows install ????? From your link
Are you connecting to it sorry for questions am new to this server stuff am
Learning ......
Are you using any anti virus or malware protection thanks
m0t0k0
Learning ......
Yep I just used the standard widows installer. You then need to follow the wiki pages on how to setup SAB. You can then follow the link in my guide on how to allow SAB through your firewall and follow my giude on how to set a scheduled task to auto start SAB every time your system is booted
RSRAVI
Have you done whs remote connection from the internet ...
I cant seem to get thru all setup domain and every things ...
but when i go to web address i get
There is a problem with this website's security certificate
then
403 Forbidden
403 Forbidden.
what does that mean
RSRAVI
Hi mate yep correct address from what I can see its too do with port forward on the router but I can't see any options on my netgear router DNG 3500
Similar threads
Trending threads
Latest News
Sky HDR launch rumoured for 27th of May
  • By Andy Bassett
  • Published
Sony 2020 8K LED and 48-inch OLED TV prices leaked
  • By Andy Bassett
  • Published
iFi launches iPhono3 Black Label phono stage
  • By Andy Bassett
  • Published
HBO Max to air 'Snyder Cut' of Justice League in 2021
  • By Andy Bassett
  • Published
Sky reveals shows for Documentary and Nature channels
  • By Andy Bassett
  • Published
