My Hitachi is finally here. Screenshots included
Discussion in 'Plasma TVs' started by ZeFab, Mar 6, 2003.
  1. ZeFab
    ZeFab
    Hi everyone!
    Just a quick word from Paris to tell you I'm so happy!
    My 42PMA400E arrived a couple of days ago and it is now proudly hanging on my wall. Picture is just amazing. I still can't figure out why ALIS panels are so controversial on this forum (or maybe the last generation is really above others)...
    Here are a few pics:
    [​IMG]
    [​IMG]
    [​IMG]
  2. steve36
    steve36
    Dec 11, 2002
    934
    Warwickshire
    +29
    Well I'm impressed.
    If only I had a large room so I did'nt have to sit 8 feet away from the plasma. By the sound of it if the fans don't get me, in some plasmas the buzzing will, or possibly the heat !!!
    (p.s. I'm not saying I do not believe you when you say it is not that noisy !).
    Ok give me a clue, how are you getting such a good picture with what I assume is Spin city. Do you have HD TV in France ????
    Steve.
  3. crawler
    crawler
    puree zefab, on te voit partout!
  4. ZeFab
    ZeFab
    Hi Steve.
    HDTV in France? Are you kidding me?:laugh: :laugh:
    Nothing scheduled yet and I guess the only HD inputs I'll get will be Blue Ray DVDs before a while.
    The spin city picture just comes from Canal+, on the cable network. The picture is excellent on that channel, but I guess the screenshot helps though.
    However, I must say that unlike many people that have posted here or on AVS Forums, I have been stunned by the picture of my display. My level of expectation was slightly lower...:D :D
  5. peve3
    peve3
    Aug 14, 2002
    436
    very nice !!, might get one my self just a few questions.
    what sort of conections has this plasma got ? plz say scart !!
    does it support pal progressive scan ?
    what resolution is it ?
    can u get a media box with it ?
    i seen it for around £2500 does that seems ok ?
    thx for any help
  6. peve3
    peve3
    Aug 14, 2002
    436
  7. ZeFab
    ZeFab
    This version has no scart.
    But you cand find the 42PD3000 that is more like a real TV:
    Tuner box with a lot of connectors (including Scart), speakers, and stand.
  8. Joel
    Joel
    What is the difference between the 42PMA400E and the 42PD3000, other than the PMA's shortage of scart?
    Joel
  9. ZeFab
    ZeFab
    Joel, are you blind? :laugh:
  10. peve3
    peve3
    Aug 14, 2002
    436
    yea but at about 600 pounds more just for a conection to scart thats crazy!! wats the cheepest 42PD3000 anybodys found i found around £2600 + pap at drc direct anybody found cheaper ?
  11. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    957
    Nasa
    +40
    I must also say it's looking very Coooooooool indeed
    Just one thing to ask , I'am also goinh to put Plasma on fireplace wall and all Av goods in fireplace ,
    How have you got all the wire / cables etc running ? ? , and what happens if any thing goes wrong ( But hope not ) :smashin:
    So all advise and help , on how to arrange
    :D
  12. ZeFab
    ZeFab
    Basically, keep it simple!:D
    I've just made a 2" hole in the wall behind the plasma panel to let the cables go through the fireplace “tunnel”.
    Cables are thus accessible both from behind the plasma or in the fireplace…
  13. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    957
    Nasa
    +40
    Thanks for that , but my old fire place keeps getting soot came down which Will not do the Plasma any good ,
    Do you get the Problem , also have you drilled a hole in the side of the fireplace for the Plugs etc
    :smashin:
  14. ZeFab
    ZeFab
    The fire place has been cleaned out and has been isolated from the roof.
    We have indeed drilled some holes on both side for the cables and plugs...
    It looks cleaner than before, and my wife is making my life much easier :D :D :rotfl:
  15. Joel
    Joel
    Ehh no, I'm Swedish.
    Yes, I can see that the other has a tuner box, but what does it provide that the screen only does not (except for the lack of scart)? Or do you acyually pay£600 extra for a Scart?
    Joel
  16. ZeFab
    ZeFab
    Well, nothing.
    But the tuner box and the speakers can be considered as a plus.
    Also, the PD3000 has no fan (thus no noise!).
    On the other hand, you can much more fine tune the picture quality of the PMA400E and the blacks are quoted to be "blacker" than on the PD3000...
