Ok well his xbox and pc are in the same room but he also wants to connect a laptop wirelessly
would this be the best way to connect everything:
Buy a wireless router and connect it to his modem, use an ethernet cable to connect the router to his xbox 360 and then use the router to get wireless internet on his laptop.
Will that work? He was going to buy the xbox 360 wireless adapter but is it really needed if everything is in the same room?
