I think my floor is level, thankfully, though I have a 20cm and 60cm (approx) and just laying on the top of the screen on the floor, the bigger one is out a little more than the smaller one… not sure how?
Yes I am . Yes the besta units have very little strength in them . So it was defo a case of finding the stronger parts to screw the draw sliders to .
Thank you matey, keeping as busy as I can.. and getting this room and cabinet sorted is certainly doing that!
That’s my problem with the besta units, I’d want to hack them apart, but they are hollow. Wood chip frame covered in veneer of of sort and the inside space filled with recycled paper. Just like solid wood or chipboard to work with.
Show off
I managed to get some wood to make my cabinet to house this lot.. 240x60x15cms.
This stuff is just oak effect chipboard furniture panels, I bought 5 at £39 a piece.
I’m thinking of three separate units to the overall width of 3m.
The center one will have the projector on, though the manual says that I need 19” either side for air flow for the fans, so I can pull that off now I have the wood. The middle one would need to be 180cm to allow for 19” each side of the projector… and I’m hoping my center speaker will go underneath it when I have the screen up on the brackets. I’m hopefully going to be able to have no correction on the screen. My ceilings are only 8ft high, so the projector will only have a certain amount of height from the floor.
That leaves 60cm for each side unit, though I can go up to 75-80cm for each side unit at max if needed I think as the wall is 11ft wide.
I’ll need to find someone to come round and cut the wood to size for me though, I’d never get it cut correctly myself.
View attachment 1686326View attachment 1686327
