MY FIRST UPGRADE.................HELP!
Discussion in 'Desktop & Laptop Computers Forum' started by loofer, Sep 12, 2001.
  1. loofer
    loofer
    Feb 2, 2001
    186
    +4
    Hi, i currently have a pc100 BX Pro 100mhz motherboard with a 466mhz Celeron and sdram. I want to upgrade the motherboard/processor and was thinking of the Asus A7V266 with a 1.4Ghz Athlon (266Mhz) and DDR Ram. could someone tell me if this seems like good value for money and also what other ancilliary hardware would i need to buy if any (cables, fans, power supply ect). Also does the memory manufacturer have any impact on performance?
    <br />Many thanks.
  2. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Hi Loofer,
    This is My setup used for Office, Gaming and HTPC:<br />Asus A7V266, 1.4 Ghz T/Bird, SK6 cooler for Chip, 512 meg DDR ram,G-Force 2 GTS Pro, 40Gb ATA100 H/Drive, Pioneer DVD rom, Sonic fury sound card, etc.
    Advise:<br />1. Use a 400+ watt power supply 300 isnt up to it ( got to replace mine).<br />2. Cooling is a big issue with the 1.4 Athlons, the SK6 is a very good cooler I'm using the Ys-tech fan not the supplied Delta. I also have 2 x 120mm case fans running at 7 volt to cool it. ( its not quiet but my PC is in an ajoining room from the Cinema so no probs).<br />All the 1.4's that I have done ( mainly Gaming rigs) have some sort of Cooling issue. I tried a cooler from Quiet PC and the temp rose 23 degrees. Mine runs at about 58-60 with the SK6. Bit high but still within limits any higher and I wouldn't like it.<br />Otherwise System is running really well using Windows XP ( highly recomended ).<br />You dont need such a high spec for a HTPC see other threads, but for gaming its awsome GF3 coming soon.. <img src="biggrin.gif" border="0">
  3. loofer
    loofer
    Feb 2, 2001
    186
    +4
    Cheers sharky, a couple of questions though, the SK6 cooler, is SK the manufacturer name? what temp should i be aiming for and are those 120mm cooling fans for the CPU or the case?
    one more thing, does the RAM manufacturer have any great bearing on performance?
    Thanks again.
  4. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Loofer,
    The SK6 is made by Thermalright. <a href="http://www.thermalright.com" target="_blank">www.thermalright.com</a>
    The 120mm fans are case fans, 80mm fans should be OK with a large case. I just chose 120's because when at 12 volt they push around 210cfm through the case for when we are gaming. At 7 volt they still push lots of air but are quieter.
    I have Crutial ram it seems good to me, I would go for a good brand ram rather than the cheep stuff. Had lots of trouble in the past with cheep ram failures.
