My first +R DL backup and probs with Panasonic dvd player
Discussion in 'Blu-ray & DVD Players & Recorders' started by steviewilson, Aug 11, 2005.
  1. steviewilson
    steviewilson
    Dec 18, 2004
    Glasgow
    I got an LG DL writer and made my first backup to test on my main DVD player, its a Panasonic DMR E50 Recorder. A good machine, good picture and sound etc but it doesnt like +r disks or RW either. I burned a backup of a disk I own to try if it plays DL disks and it doesnt - but I dunno if its the dl or +r that it doesnt like tho. Someone said something about book-type and that should play ok - apparently when burning to +r the lg auto sets to book type. The backup disk plays in my Yamada Divx player no problems ( a bit of toast would play on that tho, it plays everything) but the Panasonic says disk error or something, it wont play anyway.
    Any suggestions? Am I burning wrong? Im using Traxdata and burning at 2X, using dvddecrypter iso r then w.
    Stevie
    Glasgow
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    You need to ensure you acquire firmware that sets the booktype to DVD-ROM. How you do this depends upon which PC DVD burner you have. The LG models I have come across tend to allow it on DVD+R DL media but not with DVD+R(W). Have a look here for firmware updates and get LG specific advice here.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,185
    +3,037
    I have the same recorder and also burn DVD+R DL bitsetted to DVD ROM. They are burnt using just DVD Decrypter and a Pioneer 109 writer. The discs work fine in the E50 Recorder and my Panny HS2 DVD/HD Recorder.
    I am using Ritek Datasafe (Ritek D01 dye).
    Single layer DVD+R/+RW bitsetted also works that are done on my Ricoh writer.
