E
essexmirage
I'm starting to build a mini ITX HTPC based on Ubuntu OS and running XBMC, to go under the TV and linked to my older Yamaha Av Receiver and wanted some advice on various bits both for the build and OS etc, it's going to be a real budget build and will have to use some secondhand parts, along with some new bits like the motherboard and maybe a new SSD to keep the heat down etc
Here goes, I have an old Evesham E Style case which has already got a power supply, although the old mother board is frazzed and there is no hard drive or optical drive, so I will be using this a my base for the build, I've seen a ASRock H61M-ITX H61 Socket 1155 Motherboard on Ebuyer for just short of £56 which seems to be a decent spec ?? I would be interested to hear your views or comments on this board or the Brand ?? The other board I've looked at is the Zotac NM10-E-E D525 CPU Wi-Fi VGA HDMI Out Mini-ITX which seem to be a good spec too for a reasonable price, Zotac have a large range of mini ITX boards and and again I'd like your views or if you have any other suggestions for the motherboard/CPU, thinking of the CPU I was keen on an Intel i3 due to the unbuilt graphics but would settle for a decent dual core, and maybe a seperate graphics card, so suggestions please but keeping the budget build in mind.......... I'd be interested in a secondhand processor if one became available at the right price ?
I had originally thought of using just a DVD optical drive to be able to rip DVDs to a network drive, but due to the low cost of Blu Ray drives may be tempted to use one instead and cover Blu Ray playback too ! To be able to keep the temperature down I'd thought of running the OS on small capacity SSD and to avoid the temptation of loading loads of non needed stuff onto the PC, or maybe even getting a SATA to CF card converter and running that instead as I have a few decent size ones laying around then I could upgrade to a SSD at a later date ??
For the OS I'd thought of having a break from good old Windows and going down the Ubuntu route instead as it's free and seems to work fine with XBMC which is what I was thinking of using as the media interface, and is usable from a remote, once again any other suggestions ??
To be able to connect to my older AV amp I'd need to go with either co-ax, split channel or optical as there is no HDMI connections on the amp but obviously I'd want to run the display out through HDMI to the TV, but still be able to split audio to the amp!
So as you can see loads of ideas and questions and although I have a basic knowledge of building a computer i really need some advice on these points so my build can take some shape and get going !!
Thanks in advance for any help you can offer
