graymattor
Hi All,
I am looking to delve into the world of home cinema, I have posted in another thread about the receiver, I have been looking at the Denon X2600, which has to lead me to look at bundles that are on offer, but I am no idea if they are good or bad or I am just buying for convenience because they are a full set! eventually, I will be upgrading to Dolby Atmos speakers (or right away, not sure yet).
What speaker set up would you recommend? I am looking to spend approx £1000-£1200 for a receiver and speakers, but cheaper while keeping the same good quality is always a bonus.
Oh if it helps, the room is 5m x 5.75m, TV is central to the room (5.75m wall) there is space behind and to the side of the seating, I will be looking at floor standing/stands, Atmos speakers I guess either up-firing or ceiling mount (which comes with difficulties but not impossible, wireless for transmitting sound, I can power them in the ceiling no problem, it's running the cables to the receiver that is a little tricker)
Speakers sets i have been looking at are the Q Acoustics 7000i Plus and a 3020i bundle
I look forward to hearing what you guys recommend
Thanks, Chris
Thanks, Chris
