My first HCPC! Looking at Evesham MediaStation
Discussion in 'Desktop & Laptop Computers Forum' started by TheBoingoBandit, Feb 2, 2004.
  1. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    I desperately need a new PC (with broadband) but would also like to get an LCD projector/home cinema and music jukebox system.
    As I'm looking to move into a studio flat this year, space most likely will be at a premium.
    Rather than get Hi-Fi/AV seperates, I think that a HCPC with Windows Media Centre would be ideal instead for my situation and I've come across this system from Evesham:
    http://www.evesham.com/PCs/Info.asp?e=61E03EE2-18C4-41B0-A2DC-59031E9E6537
    3.0MHz Pentium 4
    1GB RAM
    200GB hard disk
    Epson EMP-TW10 widescreen LCD projector (bargain at an extra £500 methinks! )
    Creative Inspire P580 surround sound speakers (although I'd likely ditch these and get a better system such as the Aego P5)
    LG DVD writer
    Broadband card
    All this lot should come to a total of about £2350 (or about £2600 if I pay monthly - which I would do).
    Any comments on getting the above system?
    Before you ask, no I do not and cannot build my own system.
    Plus Evesham is a reputable dealer (to my knowledge) and I'd rather spend more money and buy from a company more likely to give good service and stick around.
    Any comments welcome! :)
    (Sticking with the rules of the forum, if you do have any bad opinion of Evesham, best to eMail me privately at johnmason@postmaster.co.uk )
  2. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +844
    As an HCPC, it doesn't suck!
    If it were me, I may consider investing more in the AV equipment (AV receiver and speakers), and less on the PC - I'd try to find/build a cheaper HCPC. In my opinion, a PC won't beat a decent separate amp and speakers for audio (ie. audio being fed from the HCPC to the amp via spdif connection for decoding).
    Just a thought.
  3. Madders
    Madders
    Jan 30, 2002
    2,316
    London
    +49
    I would try someone like Uvem.com as they will build a HTPC specific to your needs and budget, you would then be able to look at spending out on better speakers/projector - or buy secondhand speakers/projector from these forums.
    Steve
  4. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    I'd agree with the above.
    The PC spec is overkill for a HTPC. You are paying for raw processing power that you just don't need.
    Speak with a company that will be happy to build you a more conservative unit (at a better price). Uvem or Kustom will both be able to talk you through your requirements.
    You'll then have more cash to spend on a decent AV front end.
    Remember, Evesham may be happy to sell you an out-of-the-box setup, but I suspect you'll find their technical support lacking in an area which is a deviation from their core business.
    Big A
