My First Ever Cinema Build Attempt
Discussion in 'Members DIY Home Cinema Showcases' started by salsheikh, Feb 15, 2014.
  1. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    hi guys,
    after reading up on a lot of build threads and asking members for advice I have finally finished my build.
    from this:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    to this:
    [​IMG]
    [​IMG]
    even the wife got stuck in and helped sand the false wall!
  2. hillsrgood
    hillsrgood
    Nov 11, 2013
    121
    +23
    looking good :)
  3. Iffy09
    Iffy09
    Feb 17, 2014
    16
    Great setup
  4. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    thanks guys :smashin:
  5. BM08
    BM08
    Jun 24, 2012
    981
    46
    West Midlands, UK
    +189
    Very nice matey.
    I spy you on PF forum aswell ;)
  6. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    uh oh - stalker alert!!!
    i am on PF and love it!
  7. BM08
    BM08
    Jun 24, 2012
    981
    46
    West Midlands, UK
    +189
    Think i saw you in the supermarket the other day aswell?
    Only kidding lol.
    Yeah brilliant site, been on there more years than i can remember.
    So got any more plans or is it all done now?
  8. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    All done for now. Sorted out remote control interference issue too using an rf remote
  9. stevena
    stevena
    Sep 3, 2009
    28
    4
    How have you fitted the LED lights around the walls and where it meets the ceiling?
    Or is that just the glow from where you have mounted presumably behind the plasterboard where the TV is?
  10. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    I have mounted the LED lighting on the framework behind the MDF sheets. I used pvcu trim around the sides of the frame to give it a nice clean finish.
    I used a 10m LED strip so it runs behind the whole frame and up into the cable recess and up behind the tv and then around the tv - yes is it that long!
  11. stevena
    stevena
    Sep 3, 2009
    28
    4
    Nice.
    So is the light you are getting that runs across the ceiling and down the side of the 2 adjacent walls just the reflection from the strip that is mounted on the framework behind the MDF sheets?
  12. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    Spot on
  13. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    looking good.
    Love the way you get the wife to do the sanding:smashin:;)
    Love that leather couch as well.
  14. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    to be fair, she helped a lot in the process. she did most of the painting and didnt mind getting stuck in - she knew that she would have to twist my arm to get the black wallpaper on the false wall so did her bit to get what she wanted
    the leather sofas are about 13 years old, got them from Courts Sofas when it was around.
    I was very tempted to change them for these:
    Spider Leather Sofa Range | sofaworks
    i would have got a red besta unit to match the sofa's/colour theme but at £1600 for a pair and my impending 'pilgrimage to Mecca' (cost approx £12k) i decided against it.
  15. Ewan154
    Ewan154
    Aug 2, 2005
    2,038
    +88
    M8 I was being sarcastic about your wife doing the sanding.
  16. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    d'oh!
  17. Fat_Tony
    Fat_Tony
    May 14, 2009
    6,041
    +2,070
    That's a lovely set up. I love the lights but wonder if something like that would work with a projector or would it interfere with the overall picture quality?
    I'm currently going through this section "scrap booking" inspiration for my upcoming cinema relocation project.
  18. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    I think it would interfere as the lights are bright but you can adjust the brightness
  19. Fat_Tony
    Fat_Tony
    May 14, 2009
    6,041
    +2,070
    It's a great look, possibly something I could try elsewhere in the room. I love all the ideas and planning for my new cinema, ive got a perfect room for it unfortunately I barely know one end of a screwdriver from the other, and have to rely on my wife aka the man of the house, for anything DIY.
  20. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    Its not difficult to be honest but you do not some idea.
    Best to draw/plan out exactly what you want and get somebody in to help you or do it for you.
  21. psycho74
    psycho74
    Aug 23, 2005
    173
    Witham, Essex
    +32
    Looks pukka!
    Im starting mine on Monday, gotta Have my tv attached to the solid wall though because its soo heavy and bulky compared to the more modern tellies plus I need to hide its fat bum insude the wall!
    Where did you get ur leds from? My little girl is more excited about having pink lights around the tv than anything else! (Not gonna be pink shhhhh!)
  22. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    I got the leds off ebay mate. Search for led 5050 rgb
