My first build problem
Discussion in 'Desktop & Laptop Computers Forum' started by dmurray0, May 5, 2007.
  1. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    After getting all my pieces together I decided to try to build my first pc. Followed the guides to a Tee, but when I connect the monitor I get the message "No Video Signal." You can see the LED lit up on the MOBO, hear noise from the HDD, and the fans spin but nothing else. Have checked the connections for the HDD, made sure the 2 PSU inputs are connected (the 4 pin and 24 pin) and tried the memory in different slots, but still no post. Any ideas what else to do, PLEASE????
  2. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    Is there on-board video and a video card installed? If so you could try the other card.
    Other than that do you get any beeps?
  3. ufitsy
    ufitsy
    Aug 18, 2004
    3,280
    103
    Midlands
    +353
    Unplug the Hard drive(s) see if you gat any output.
  4. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Its onboard video and no beeps. It's an ASUS AM2 M2N PVVM board with a X2 AMD 4600. You turn it on, fans start,LED is on the board, and noise from the HDD, although it doesnt sound like it is booting up. Thats the best way I can describe it.
  5. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Nope, no joy. Any other suggestions?
  6. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    have you tried clearing the CMOS just in case? (batt out, change jumpers, leave for 10 secs, change jumpers back, replace batt.)
  7. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Yup, tried it too. Speaking to a mate earlier who looked at it. He says the HDD is ok, but he thinks it either the CPU or mobo. Will phone Scan on Monday and see what they can do.
  8. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    Try removing the memory, then if you have multi sticks putting one back at a time in different slots.
    You could also try reseating the CPU.
  9. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    I reseated the CPU last night and it made no difference. I only have 1x1gb DDR2 stick and don't know anybody who has spare DDR2 memory to test it out. All my mates have DDR. Anybody live near me and fancy lending me a stick for a few minutes!!!!
  10. Keyman
    Keyman
    Many Newbie forget about the 4 pin CPU power. Check that
  11. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Already tried that. Both pins are in. Scan are closed today, so will have to wait until tomorrow.
  12. Keyman
    Keyman
    If you are confident enough, try to boot with the MB out of the case (be careful not to short circuit anything on back of MB). MB, CPU, RAM and heatsink only (if the MB has got onboard graphics). I have also seen short circuit on the back on the MB by having the 'standoffs' at the wrong places. Also make sure there is no power reqired by the GC.
    If this does boot, it is likely you have a faulty part. By going mail order on components, this is one of the risk you take. Just say 1% dead on arrival on components, if there was 10 components, there is a 10% chance the computer would not work from day 1. Looks like you maybe one of them.
    How about a list of the components with names, I can have a good guess which one is the likely suspect. (I do the purchasing for a few computer shops and I roughly know their failure rate and quality etc)
  13. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Cheers for the info.Parts are:
    Case Antec nsk2400
    Board ASUS AM2M2N PVM
    CPU AMD 4600X2
    Memory KINGSTON ddr2 kvr667d2n5/1g
    HDD Samsung 250gb Sata Spinpoint
    Heatsink Thermalright SI-128
    Will try the outside test later. Have to head out now. Thanks again for the advice.
  14. Keyman
    Keyman
    Psu?
  15. Keyman
    Keyman
    Ah, a media centre type desktop case with PSU inside. Really do not know the quality of this one...
  16. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Similar to the Antec Fusion but no VFD basically.
  17. Keyman
    Keyman
    I would say the CPU, memory, and harddrive are not causing this problem.
    My guess is (in this order of likelyhood)
    1. MB (ASUS has picked up quite a few dead on arrival in the last 2 years)
    2. PSU
    3. HS (you may be surprised but I have seen a few)
    Best of luck
  18. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    Will try the stock heastink later and then see what happens,cheers
  19. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    I've given up buying ASUS boards for people now due to the amount of DOA's I've had.
  20. Keyman
    Keyman
    For this very reason, I stop buying ASUS for my shops from about 2 years ago.
    My choice right now:
    Budget: Foxconn
    High End: Gigabyte
  21. skippyonspeed
    skippyonspeed
    Is this part no. correct?
    Can't find any ref
    Anyway if it has 2 memory slots. Most boards require both to be occupied with equal size sticks preferably identical. Otherwise you get the sort of symptoms you describe.
  22. dmurray0
    dmurray0
    Dec 8, 2006
    246
    Antrim
    +17
    It was actually a Asus am2 pv-vm. OOpsw, spelling mistake. Took machine apart for the third time and put it together again, and now it works perfectly. STRANGE!!!! Thanks everybody for their help anyway.
