bstonehouse said:
This gives a great finish - can this method be used in Photoshop Elements 4 ?
I'm not really sure, as I've never used Elements.
If you want to try, the Photoshop method is as follows;
-Change the image Mode to LAB (as opposed to RGB).
-Go to the Channels, and you should see 'Luminance, A, and B' channels.
-Right click the A channel and delete it
-Do the same for the B channel
-Change the image to Greyscale
-And finally change back to RGB
You can now tweak the levels and curves (if you have those plug-ins) to get the black and white points spot on.
Give it a try to see if it works.
Anyway... I'm going off topic!!!! Sorry!
