My Epson printer won't recognise new refills?
al shookup
I have an Epson SX415 and normally use Jet Tec compatible ink cartridges without a problem. I have just bought a new supply but the printer refuses to recognise the new refills and will not work. I do believe there is a way to make it accept compatibles but if anyone can advise me how, please do so.
thanks
enigma1701
I had a sx425, ended up in the bin after I had hassle with refills! Doesn't help your problem but might make you feel better! A new printer is less than the cost of original inks!
al shookup
Thanks ..I tried running the printer with just one ink cartridge in then two then three and it told me on the fourth (Cyan) that it would not recognise it. So, on the assumption that it is this cartridge only, I have ordered another Cyan and will give it once last try before dumping it. Which new printer to buy is confusing me because all have good reviews and bad reviews.
