MY DVD is scratched unable to backup possible to repair DVD Decrypter - read errors ?
Discussion in 'Movie Forum' started by jamieuk23, Jul 2, 2005.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    Hi I bought a DVD/Ps2 game from ebay (singstar karaoke game). from playing the game last night it would some times just freeze up when loading to the main game play.
    I have tried to make a backup of the disk using DVD decrypter but I keep on gettign read errors at 26%.
    looking at the disk I have noticed it has a few scratches on it so I am guessing this is the mian cause of the problem.
    I have cleaned the DVD with specail DVD/CD cleaner spray + tried backing it up using another DVD writer I ahve on my PC and I still get the errors at 26%.
    It does give me the option in DVD decrypter to ignore read errors, but I woudl only end up with the same bad data the same as the orginal but on a diffrent DVD-r disk.
    do you no off any way I can fix these reading errors using certian software ?? + what are my options here ??
    thanks for your help guys !!
    jamie
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,770
    Bristol
    +6,374
    Best thing to do would be to take it to a rental shop that does a disc repair service or to buy one of those disc repair kits.
  3. Razor
    Razor
    Dec 15, 2004
    37,550
    2
    +12,509
    I think Special Reserve sell these kits. I couldnt find it on their site but I have seen them in their magzine. Give them a ring. :D
    http://specialreserve.co.uk/
    :thumbsup:
  4. DVD-RAM
    DVD-RAM
    I have heard that plastic polish works, not tried it though.
  5. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    any 1 no of any software that can allow me to rip the game to my hard drive and fix the errors at the same time. ???
  6. dfield2000
    dfield2000
    Jul 16, 2002
    957
    Cardiff
    +5
    I'm not sure about PS/2 games - I'm talking about movies on DVD now - but this might work for a PS2 disk also. A friend of mine had a badly scratched disk that wouldn't work, so he used T-Cut on it. He reckons that all scratches were removed and the disk now reads fine.
    From what I understand, you can afford to loose some of the protetive layer from the top surface of the disk - you just need to remove enought so that the scratches are not so deep.
    NOTE - I HAVEN'T TRIED THIS MYSELF YET, SO IF YOU TRY THIS THEN IT IS ENTIRELY AT YOUR OWN RISK !!
  7. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,795
    Essex
    +2,955
    I have used brasso on my discs before and it works very well.
  8. nero0410
    nero0410
    Jan 5, 2004
    11,659
    southwest
    +4,435
    I use t-cut to repair my discs :rolleyes: it sort of takes off a couple of layers to get scratches out etc.... I only do it if it really needs it though
    tris
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    all these make shift things, although some work, are risky, i scratched halo2 on the day of release and was brickin it. I tried toothpaste, no go, and didnt want to risk anything like t cut as id tried on a test disc and it didnt look good.
    so i bought this:
    http://www.play.com/play247.asp?pa=...products&searchstring=wipe+out+cd&page=search
    and it actually works really well, it scratches tiny scractches all around major scratches, and the lasar can see through these "microscopic" scratches. theres enough for tens of generous applications as well. Its fixed all my old scratched discs, the only time it hasnt worked is when the foil layer itself has been damaged. Give it a go, for £6.49 you cant go wrong!
