My DV79, is it dead?
Discussion in 'Arcam Owners' Forum' started by philthyanimal, Jul 1, 2005.
  1. philthyanimal
    philthyanimal
    When i try and play DVD's on my 79 it makes a horrible clicking noise while saying "load" then flashes up no disc.
    Cant eject the disc, then the machine switches itself off, restarts and i can open the drawer.
    Anyone else ebncountered this?
  2. Hifi addict
    Hifi addict
    no I have not.
    Have you checked the DVD in your PC? maybe it's a very bad DVD.
    1 other thing that could be the case is that this DVD is from another region. If so, then you have to make your DV79 region free. Search this forum on how to do that. There are multiple threads on it
  3. philthyanimal
    philthyanimal
    Its all my DVD's its doing it for.
    I've tried them in my pio 757i(which i'm now having to use) and they work
  4. Hifi addict
    Hifi addict
    have you tried to put a CD in the player and see if that plays. if it's the same story with a CD then I assume you have to return it to the dealer.
  5. philthyanimal
    philthyanimal
    I'll try a CD tonight.
  6. Hifi addict
    Hifi addict
    ok. and 1 more question: did you have this issue as from day one or did it happen just like that?
    the issue could still be that ALL your DVD's have a wrong regioncode
  7. philthyanimal
    philthyanimal
    nah, started about a week ago, the odd disc that had worked before would flag bad disc, then its got to how it is now.
    Its region modded so its not that. I'll take it back on saturday, see what they can do with it.
    Shame really 'cos its a superb player
  8. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    Would you describe Is the clicking noise mechanical or electrical in origin? Does the unit get very hot in operation?
  9. philthyanimal
    philthyanimal
    Its a mechanical clicking sound, a loud ticking almost
  10. Hifi addict
    Hifi addict
    i think it's the same tick what you get when you put in a really unreadable disk. just enter a normal PC cd and listen what happens.... that should be the same sound I assume
  11. sleepa
    sleepa
    Jan 20, 2004
    27
    Maidenhead
    Spookily my dv89 has just done the same thing (except more gradually over a couple of months) so let us know how you get on with any repair...
    BTW, does anyone know if I need to return to the dealer I bought from, or will a nearer one honour the warrranty/affect the repair? Will be ages before i can get back to the original shop (and twice at that probably)
