My custom made AV rack
Oily
I made this because i couldn't find anything suitable or if i did it was to expensive.Its made from ally box section and 10mm acrylic for the shelves.I milled the slots out at work and had the acrylic cut to size,all the edges were rounded off so the kids couldn't slice themselves open on them ;) I installed LED's in the rear of the shelves.
Any comments ideas etc much appreciated
And oh,i made the speaker stands aswell :smashin:
attachment.php
attachment.php
attachment.php
attachment.php
inzaman
I'd agree it looks pretty smart.
thfccambs
Very good job mate.:thumbsup:
Knightshade
Nice Work:smashin:
cossie
Looks good
I've just asked my mate who works at the family joinery firm to make me a cabinet with 8mm glass shelves which I also wish to back light with Led strips.
Which make of Led did you use and any chance of a photo of how you attached them to shelves?
Oily
Looks good
I used some high intensity LED's out of some pushbike lights(don't ask why:D)
To mount them i just drilled into the acrylic with the appropriate sized drill bit
There some more photos here:
http://www.avforums.com/forums/showthread.php?t=606850
Knightshade
You could've gone the whole hog and put in 'knightrider' style leds......:thumbsdow
Per156GTA
I like that very much.
What is the total height of the unit, to the underside of the TV?
You might be better to place the centre speaker under the TV instead of the floor, for the sake of clarity of dialogue!
Per
badbob
That centre speaker will sound lousy on the floor. Can't you space out the speakers more?
Matt_C
Per
Whats the betting that it isn't finished yet, and that the top shelf there is for the centre speaker - but looking at the state of the room everything hasn't been put in place yet.......? ;)
badbob
I would also remove those pink LED's. Looks tacky and a eyesore. And buy a better subwoofer. :D
inzaman
And to quote badbob's signature;
"Remember, if you like it, it doesn't matter what others think." :smoke::cool:
Oily
Per
Total height 115cm.A few people have said move the speaker,i'm new to this av malarky so i didn't know where to position it :blush: I'll move asap
Why do they need to be spaced out more,the B&W manual says space them out 1.5 metres which they are.Besides they can't go any further due to the doorway.
You guessed it :smashin:
They're red and whats wrong with the subwoofer?
Per156GTA
For me, that is an ideal height, as then the TV is at perfect eye height when seated.
Too many people place the sets way too high!
Top job, well done :smashin:
Per
Oily
Per
Thanks.
Just an update,i've moved the speaker as advised.We'll see if i can tell the difference :blush:
Greg Hook
Moderator & Reviewer
Nice! :thumbsup:
At least you remembered to put some clothes on when you took the photo. :rotfl:
visioneer
I agree with comments so far, top job :thumbsup:
One thought I had regarding the LED's was that if you had used frosted acrylic then the light might have been dispersed across the shelf better giving a more diffuse look. This assumes of course that the edges could be frosted too, not sure if that's possible or not.
Oily
Hmmmm,i not sure either,the guy said he would polish the edges so i'm guessing you could get frosted :confused:
Latest News
What's new on Blu-ray Special - The Cinema of Zhang Yimou & Gong Li
  • By Mark Costello
  • Published
Black Friday 2021: What you need to know
  • By Andy Bassett
  • Published
AVForums Podcast: 24th November 2021
  • By Phil Hinton
  • Published
Panasonic 2021 TV update brings full 4K resolution with VRR and HFR
  • By Andy Bassett
  • Published
Best Hi-Fi Products of 2021 - Editor's Choice Awards
  • By Ed Selley
  • Published
