My current set up before and after
Discussion in 'Home Cinema Building DIY' started by Montel, Sep 12, 2007.
  1. Montel
    Montel
    Sep 11, 2007
    13
    Current System
    I just thought that I would post a picture of my current setup and describe it, before install my new HD kit. The picture is 2 years old but the setup looks much the same now.
    Screen is recessed into the wall and it looks awesome!. Fortunately the build was quite straightforward as I have a wall with a 12cm soundproofing layer inside the room which I cut out to fit the current screen Panasonic TH-42PW6. AV Cables are routed in rectangular tumble dryer vent ducts fitted into the soundproofing layer. A great solution that allows you to get those high end scart leads through. Power is provided by a separate ducting tube. The wall was fully re-plastered with a tight finish. The screen itself sits about 3cm behind the wall line, which has a great effect of putting the back of the box in shadow, no matter what lighting I use.
    The upgrade
    The kit list: Pioneer 508XD, Toshiba HD-XE1, PS3 and Sky HD.
    The New kit has arrived and I have temporarily set the panel using a proper Pioneer stand, rest of equipment just fits on existing stand. Photo to follow. Ps. the Pioneer picture is incredible!
    The job
    Resize the hole to fit the 50inch Pioneer, re-plaster, decorate and install. Will be fun, I’ll keep you posted!
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    Very neat, a job well done.:thumbsup:
  3. MarkP80
    MarkP80
    Jan 15, 2005
    1,004
    Aberdoon!
    +110
    Perfect setup to have a projector and an electric screen come down for the big movies!.....
    MarkP
