cracking shot and the sky is nicely exposed. did you use any filters or anything?
Hi Scout,
wey it's grate man!
-beautiful capture.
Can I ask a couple questions?
What focal length did you shoot your piccy at?
....and I see there is a slight distortion on the bridge. Therefore, because the focal length of the zoom is so small on the 10-20, would a prime 20mm Sigma lens produce nearly the same frame size and be without the lens distortion?
I am slightly confused about whether to go for a fixed or zoom lens. I am mainly wanting it for landscape shots with some interior shooting.
Thanks in advance
Graham
