My chipset fan has died.
Discussion in 'Computer Components' started by Sharp Shard, Sep 18, 2007.
  1. Sharp Shard
    Sharp Shard
    Aug 16, 2005
    271
    +5
    As the title says, my chipset fan has died - the 40mm x 40mm one (I don't know if that's the universal standard?)
    Anyway, I've orded a new one, but wanted to ask about the 'spray' or solution I am supposed to apply to the bottom of it before attaching it to the motherboard, could anyone tell me what that is and how much it costs?
    Thanks.
  2. sibeer
    sibeer
    Jul 17, 2005
    2,844
    West Kirby, Wirral
    +129
  3. Sharp Shard
    Sharp Shard
    Aug 16, 2005
    271
    +5
  4. BrokenArrow
    BrokenArrow
    Sep 7, 2006
    894
    28
    Berkshire
    +68
    Are you talking about the base of the heatsink or the actual fan?
  5. Sharp Shard
    Sharp Shard
    Aug 16, 2005
    271
    +5
    The heatsink. Sorry if I didn't make that clear.
  6. BrokenArrow
    BrokenArrow
    Sep 7, 2006
    894
    28
    Berkshire
    +68
    That's fine. Arctic Silver is probably what you want, assuming the heatsink clips on and doesn't rely on the sticky kind of thermal paste - Arctic Silver doesn't have any adhesive qualities.
    I thought I'd clear up whether it was the heatsink or fan because you might have been asking about how to attach the fan to the heatsink.
    Thermal paste is put between the chip and the heatsink to fill the gaps. It conducts heat better than air, which is why it's used. So for a northbridge or southbridge chip you would only need a very small amount of paste on the chip because it has a small surface area. You could spread the paste very thinly over the chip and then attach the heatsink.
  7. GLP1
    GLP1
    Sep 8, 2005
    209
    28
    +34
    You will need to clean the surface of the chip with isopropyl alcohol & cotton bud to remove the old paste before applying the new artic silver.
    Gavin
