My big TV swap plan
Discussion in 'What Is The Best TV For You?' started by robnotbob, Jun 24, 2015.
  1. robnotbob
    robnotbob
    Jun 24, 2015
    2
    usa
    My swap plan:
    Move living room tv (Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV) to bedroom, replacing crappy no-name 740 18" tv, and adding small sound bar if needed. [media in bedroom: over air TV and roku - no cable)
    Upgrade living room tv to 40'-50" 1080p set with 3 HDMI inputs (roku, DB DVD, sound bar), connecting existing sound bar: Samsung HW-F450 2.1 Channel 280-Watt Soundbar [media in living room: BD DVD, over air TV, and roku - no cable)
    I'd like to spend under $500 US on the 40'-50" 1080p set with 3 HDMI inputs. With this budget, either 4K or OLED are out of my range I think. Since I use Roku - a smart tv is not necessary.
    So far looking at:
    VIZIO E50-C1 50-Inch 1080p Smart LED HDTV
    Amazon.com: VIZIO E50-C1 50-Inch 1080p Smart LED HDTV: Electronics
    Samsung UN48H5500 48-Inch 1080p 60Hz Smart LED TV (2014 Model)
    Amazon.com: Samsung UN40H5500 40-Inch 1080p 60Hz Smart LED TV (2014 Model): Electronics
    Are there others? Is my price point too low? Thoughts?
  2. dr no
    dr no
    Mar 30, 2004
    12,953
    +7,398
    Just to let you know this a UK based AV Forum. We may not be familiar with some of the US specific brands and of course pricings are a different issue altogether :)
  3. robnotbob
    robnotbob
    Jun 24, 2015
    2
    usa
    This explains a lot. ;]
  4. simonlewis
    simonlewis
    Jul 31, 2014
    4,704
    stockport
    +1,757
