My best TVs for next gen gaming 2020-21
Dodgexander
By the way the tv is available as a 50" as well as the 55" which was the thread with the bad feeback. Is it possible the 50" screen would be any different in reliability/issues. I am clutching a straws here:(
There's bad feedback on every TV. Unless the TV is not popular, in which case there are less people to comment on the bad feedback. All sizes of the U7Q should be identical.
All comes down to where to make your compromises. Some people may be put off by the fact Hisense use a very basic and buggier smart OS and prefer to go with Samsung instead. But then if you go with Samsung instead you basically get unusable HDR in all titles.
Should think about panel types too. VA panels have more blur than IPS. So they may prefer one panel type over another.
kbfern
Thank's Dodge, appreciate all tv's have some bad feeback even the expensive ones. I have a £2k OLED and some moan about that model too, there is probably no perfect tv at any price:)
I don't think the smart features are that important to them as they can access that side of things via the PS5.
I will relay all the info to them and see where we go from here. I suspect there will be no more money available though so might just have to take pot luck with the Hisense and hope it's ok.
Dodgexander
No problem. If they can't raise the budget to a high tier model, or at least a mid tier like the Sony XH9005 then you should determine whether they want a TV that uses a VA panel or IPS. For gamers its a very important choice since VA has better blacks, uniformity and contrast. But IPS has less motion blur and better viewing angles.
If they want a TV using an IPS panel, you can't consider 50" models like the U7Q or even the 50" Samsung's and should be looking at 49" models from LG instead. For example, the Nano85/86 series.
kbfern
Thank you will take a look at the LG Nano 85/86 series @ 49" so what those look like, although viewing angles are not a problem for them as they sit straight on to the tv. I suspect the VA is better for them if it has better blacks uniformity and contrast.
Is the U7Q 55" an IPS or VA?
kbfern
Thanks Dodge my daughter is now considering upping the budget and just getting one tv for now and waiting for a second 2nd tv till later on.
Assuming she wants most of her wish list, would £700 £800 be enough or what would have to be found to get a first class LCD/ULED that is free of most of the bug bears of the £500 sets.
Suitable for gaming with PS5, decent HDR/good black/contrast levels/ most HDR versions/low lag/ wide viewing angle not to critical.,
And can you specify a few solid 48"-55" models that I can look into please.
Keith
Dodgexander
Keith
That would open up TVs like the Hisense U8Q and Sony XH9005. The Samsung Q80T which ticks all boxes is around £1000 and the cheapest way to get everything right.
With the two mentioned TVs is about choosing your compromises. The Sony has support for a 120hz input and has variable refresh rate support planned, although it does have a problem with constant blur in 120hz mode. The downside is the Sony barely gets much brighter than the cheaper Hisense U7Q at only 750nits, which falls short of the 1000 baseline. Sony's smart system is pretty decent, and the TV feels fast to use.
The Hisense U8Q on the other hand can reach around 1500 nits and will be give less problems when using the TV with HDR content than the Sony, but despite having a 120hz panel will run games only at 60hz not 120hz. It also has a problem with blur, but only with darker colours and only in certain content.
If you step down to 49" your options are slim, there's not as much choice at smaller sizes and TVs have worse specs. The TV to go for at 49" would be the Sony XH9505 but I think its over budget.
kbfern
Brilliant :thumbsup: , thanks Dodge will see if we can stretch to those and will bone up on those models.:)
steb9780
Could be worth waiting to see if there are any price drops with new models coming out. The Q80T was as low as £800-£900 around Xmas. Could be worth holding out a little while longer to see what drops start happening. Will get all the benefits of the new console with that TV. Seen one with an xbox series x and it looked really good the HDR was brilliant.
steb9780
I have found the 75" Q95T for £1724.
I'm seriously considering pulling the trigger on that.
Excellent price that. I have a 55 and 65 inch one. Love the tv. That price is excellent, got the 65" for around £1800 in November (was 2k but sold free soundbar for £200). So to get 75" for that price is excellent. My 55" is a near perfect screen. Never notice the FALD grid or much DSE. I wasn't as lucky with the 65". It shows some FALD grid on lower quality content, with solid backgrounds that are moving. Its odd as its pretty much non existent on 4k blu rays and xbox games. Its not as bad as some examples i have seen, but i notice it. The missus doesn't see it. I am toying with getting samsung to replace the panel, but might end up worse.
so as i understand in non oled at 55" if one can afford it , x950h is the way to go for lcd , if you are willing to sacrifice hdmi 2.1 120hz. Is 2.1 hdmi actually usefull in gaming? if we had two same tvs side by side, and play same game on ps5 or anything, hdmi 2.0b on one and 2.1 on the other... what would be the diference on human eye? lets say 4k,60hz+hdr. or let me put it, this way.
x900h with latest update on 4k 120hz hdr vs x950h 4k 60hz hdr.
[email protected]
Just came across this thread when trying to do some research on the 65AE7400.......anyone seen an actual proper review?
It's on offer at Costco with 5 year warrantyu for £468.99 at the moment, so keen to find out how it compares!
Jotatvsmonitors
So, do you think the new LCD of sony (2021 "j") will be like xh90 (2020) that can not reproduce hdmi 2.1 content?
(2021 LCD not all tvs does not have vrr, like xh90)
The only tv With gaming specs below 48' is only one of all the tvs of 2021, the sony x85j 43', some people recommended me Monitors but Monitors lack lot of things
Will sony x85j be a good one? Its a edge led, so hdr can still be great?
Dodgexander
(2021 LCD tvs does not have vrr, like xh90)
Do you mean it won't reproduce HDR content very well? That entirely depends on the peak brightness and local dimming performance of the TV. We'll know more when we see reviews.
Smaller TVs/lower range than the X90 will definitely not be suitable TVs, those will be edge lit with lower brightness and no local dimming at all.
At smaller sizes, TVs have worse specs, if the trend continues in 21 the Sony X85J at 43" will use a 120hz IPS panel, its HDR capabilities will be woeful.
Jotatvsmonitors
Salutes Dogexander as always thanks for commenting
Thing is I ask cause I only hace 2,7 or 2,9 meters to the tv, cx 55" I can purchase it at a good minimum price, but will it be a lot big for less than 3 meters?
I have a 32inch, size comparison says that 55 is 175% larger, so huge xDD, that is why I asked about a 43", and the only one, x85j
(48 cx is like 250 or 300 more money than cx, and for that price c1 of 48 is best, its also an option, instead of 175%, 125%, but for more money how weird xDD)
Spectator
For movie viewing recommended distance is ~2 metres for 65", and mixed usage ~2,7 metres for 65".
So no, 55" is not too big for under 3 metres distance. You can't see 4K vs 1080p difference from your distance with a 55" TV.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
