My bedroom
Discussion in 'Members DIY Home Cinema Showcases' started by Bubbauk, Jun 2, 2005.
  1. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    [​IMG]
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Certainly looks nice, is there any chance of a more comprehensive description of your equipment, what you like about, why you chose it and anything you'd like to try next?
    Out of interest, would you be able to move your main speakers further away from the TV to aid imaging or isn't there enough space? :)
  3. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    Info on my equipment is in my sig, i like all of it, wouldnt change a bit apart from the ntl, would prefer sky but i supose ntl will have to do for now. Atm i looking to upgrade the way my equipment is setup as currently i have my dvd player ran through my amp through s video aswell as my pc, so i am going to buy 2 new scart cables and run my dvd player through the ntl box then to the tv so it should improve quality on both of them, i am also purchasing a new phono cable to link my tv to the amp as i am usuing a generic phono cable i just found lyeing around the house from years ago. Room is very limited for the speakers but i have a spaced them apart a bit more and moved them further back a bit, isnt much more i can do as my wardrobe is on one side and my door is on the other.
    I chose this equipment because it was in my budget and people reccomended it to me, on these forums and a couple of others. I dont think i will be upgrading anything major for a while since i am still in school and i should really be trying to save for a car.
