O
Ovation
To whom it may concern:
Last Monday, my dealer received my AVR200 via UPS and I picked it up that evening. The following afternoon, I hooked everything up (checked and re-checked--this is the 10th home cinema system I've hooked up), turned on the AVR200, and within 3 seconds, a "POP" and no display. The green power light was on but that was it. I brought it back that evening, was told that a faulty circuit kept blowing fuses and I would receive a new one by Thurs evening, Friday morning at the latest. As it turns out, the American distributor did not send the package as quickly as promised and I received only today. I've just spent about two hours moving equipment and furniture and hooking everything up (checking and re-checking all the connections) and when I turned it on, the same "POP" and no display. I am using the exact same interconnects and speaker wire that worked perfectly well with my old Denon AVR1600 (which I sold to my brother-in-law). I verified that the impedence switch was at the correct setting, the voltage switch was at the correct setting and that no bare wires were in any way touching either each other or the chassis.
I really wanted to enjoy my Arcam. The two-channel integrated amp my dealer lent me while I was waiting was wonderful and I hated parting with it. However, having this problem twice makes me reluctant to try my luck again.
