My Apps no longer work :-(
Discussion in 'iPhone Forum' started by Becco, Feb 1, 2009.
Tags:
  1. Becco
    Becco
    May 2, 2006
    180
    +8
    I've just updated to firmware 2.2.1 and loaded a bunch of music and photo's etc to my iphone....but now none of my app's work anymore!! The icons are there, but when i click on them the app starts to load then resets back to the main page!
    Can anyone help??? (its not jailbroken) :(
  2. mikeb71
    mikeb71
    Oct 18, 2005
    276
    28
    Rainham
    +25
    Same here....Wunder Radio no longer works nor does Free RSS plus some others :mad:
    Hopefully some updates will be issued shortly.
  3. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,296
    +677
    Try d/loading a free app and try it then all apps should work again.Cant believe apple havent fixed this problem yet.
  4. mikeb71
    mikeb71
    Oct 18, 2005
    276
    28
    Rainham
    +25
    I did delete one of the problem apps which was then fine yesterday but today it doesn't work again (although I did resync my iPhone with iTunes last night so maybe that's caused the problem?) :(
  5. Becco
    Becco
    May 2, 2006
    180
    +8
    I deleted one of my apps and reloaded....that seems to have done the trick :smashin:
  6. mikeb71
    mikeb71
    Oct 18, 2005
    276
    28
    Rainham
    +25
    I'll try again and see whether it still works after I re-sync with itunes again.
