My amp sounds awful.....
Discussion in 'AV Receivers & Amplifiers' started by paulr, Apr 7, 2005.
  1. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    I recently bought a s/hand Marantz PM17 integrated amp,but tbh it sounds awful.Very bassy and boxed in.It was meant to replace my old Pioneer A400 but it sounds worse (by a long way).
    How do i know if there is a fault,or if a component is "on the way out".Do amps deteriorate?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Waht speakers/cd player and interconnects/speaker cable do you use? Any of these could also be making the difference. It could be the marantz is bringing out the worst in your setup that the old pioneer didnt.
    Have you got any other speakers you can borrow from a friend? Try them side by side and see.
  3. SKA.face
    SKA.face
    Is it worth rechecking the cables?Everything wired up correctly?The Pioneer A400 are quite bright,the Marantz will be far smoother,maybe just a bit of a sonic adjustment needed.
  4. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    I've tried different sets of speakers.Yes,the A400 is quite bright,but after 12 years i like it.
    In comparison the Marantz is a much duller sound.
