My amp keeps turning itself off
Discussion in 'AV Receivers & Amplifiers' started by Stampax, Aug 25, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,314
    Northampton
    +52
    I have an old Sony amp that keeps turning itself off (well into stanbye).....
    Anyone know if this suggests its simply fit for the bin, or is there likely to be a simple solution???
  2. narcoticsuite
    narcoticsuite
    Jul 7, 2005
    83
    Don't think there is a simple solution. The same thing happened to a sherwood av amp of mine after i had used it all night for party music at very high volumes. I had blown the power supply apparently, just from over driving it. Totally my fault, it was played very loud for hours and had a VCR on top of it which was blocking up the ventilation holes on top of the amp. The top of the amp and the bottom of the VCR were too hot to touch and there was a horrible baking smell coming from the amp.
    I got it fixed under warranty, no idea how much it would cost normally.
  3. AMc
    AMc
    Nov 20, 2000
    5,823
    Near Norwich
    +2,342
    Does it turn itself off after some time? - suggests it's overheating for some reason.
    Or immediately? - suggests it's got a short circuit probably a bit of speaker wire touching across two contacts at the back.
