My amp is humming (Triumph TA-250)
Discussion in 'AV Receivers & Amplifiers' started by Simon1987, Sep 16, 2005.
  1. Simon1987
    Simon1987
    Sep 15, 2005
    34
    Hi guys, I have a old amp it's a...
    Triumph TA-250
    And it makes a slight humming noise :S I think it has something to do with the power.
    It also has a grounding screw on the back, How can I ground it?
    also I feel that I get headaches when the amp is on... Is this possible? (Maybe its giving a hum on some freaquancy too high for my ears or something)
  2. gnikolaidis
    gnikolaidis
    Well, why dont you try to buy a new amp?
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    It's probably transformer hum. You could try, and I am not kidding you, do drip glue into the windings of the transformer.
    Make sure you disconnect the power before opening the unit.
    The grounding screw is for grounding turntables, not for grounding the amp.
    Sorry, no idea. (Anything is possible. ;) )
